Offroad & 4x4
4wd and pavement
Old Dec 17, 2003 | 09:09 PM
kmorg's Avatar
kmorg
Question 4wd and pavement
Does anyone have any idea why the Ford manual says not to drive on dry pavement while in 4wd? Winter here in WV and you can go from a snowy side road to a cleared one and you don't have time to put in park and switch back. Will this cause problems?
Old Dec 17, 2003 | 09:41 PM
92 f150300six's Avatar
92 f150300six
i think thats just for low lock. if it was going to break any thing the np 203 transfercase wouldnt be around
Old Dec 17, 2003 | 09:51 PM
4starcstms's Avatar
4starcstms
The book says to only drive non paved roads because the loose material (gravel, dirt, sand, Mud, Snow) will take up any difference in the driveline between the front and the back, with the soft surface the wheels can slip if they need to and you wont relaly notice it.
btw something similar to that is in Chiltons Manuals
Old Dec 17, 2003 | 10:01 PM
tellico racing's Avatar
tellico racing
Re: 4wd and pavement
You can shift in and out of high range while moving. You do need to stop to put it in and out of low range though.
Old Dec 18, 2003 | 12:13 AM
fishmanndotcom's Avatar
fishmanndotcom
The reason is b/c the when you turn, one wheel is spinning a lil faster than the other (the outside tire) and so to compensate for this something has to give...usually a tire but if it has a really good grip on the road/surface it could very easily break u-joints or even shafts if they are the smaller D30's or something.
no one says you can't....I have had to in the past but only in extreme situations where I had no choice and I babied it! It is just really strenuous on the drivetrain. Now if you are going down a straight line like a drag strip it wouldn't hurt anything!
92 f150300six-
no man, this is for 4-wheel drive period lo and hi
mine seems to shift into 4-lo on the fly just throw it up in neutral, pull the stick back...and voila! 4-lo...then you gotta hold on to the dash so you don't bust your head when you pull it down in 1st gear, lol!
-jason-
Old Dec 18, 2003 | 08:08 AM
JeremyH's Avatar
JeremyH
Not on an open differential. Remember that the spider gears are still present (unless he has a locker) and are still doing their job.
Old Dec 18, 2003 | 08:46 AM
RRMike's Avatar
RRMike
The reason is not because one tire on an axle turns faster than another. This happens in 2wd. The reason is that an entire axle (the front) travels a longer distance than the rear which always cuts the corner a little. This results in binding at the transfer case because the transfer case in our trucks locks the front and rear driveshafts together making them turn the same speed. This pressure is relieved by the tires being able to slip slightly on loose surfaces.
The np203 which was mentioned earlier has a built in differential which allows the front and rear driveshafts to turn different speeds when not in the "lock" position. If you don't believe me jack up the front of any np203 equiped rig and it won't move until you put it in lock. Me and a buddy learned this by taking his front driveline out so we could do burnouts and found that the truck wouldn't move. It just sent all the power to the (missing) front driveline like an open differential which is exactly what it is when not in the lock position (either high or low lock).
Old Dec 18, 2003 | 09:00 AM
sasnaker's Avatar
sasnaker
so without the transfer case moving the driveshafts at different speeds, the front axle moves slower than the rear? is that what your saying? im wondering what this means:
"The reason is that an entire axle (the front) travels a longer distance than the rear"
maybe im thinkin too much on it, but just sounded interesting,
just wondrin
Old Dec 18, 2003 | 09:37 AM
fishmanndotcom
ok i was close
-jason-
Old Dec 18, 2003 | 10:11 AM
JeremyH's Avatar
JeremyH
just wondrin
No, what he is saying is that the front axle travels a longer distance than the rear does. You can see this when your tires are wet and you drive on a dry surface and make a turn. You'll notice that the front tires make tracks on the exact path that you point them......the rears (as he put it) "cut the corner".
Old Dec 18, 2003 | 04:34 PM
RRMike's Avatar
RRMike
Right! The front axle turns faster than the rear axle whenever you go around a corner. It's very slight but enough to cause binding in the drivetrain when the tires can't slip a little.
Old Dec 18, 2003 | 05:32 PM
MustangGT221's Avatar
MustangGT221
Also, tires with different air pressure and weight load turn at different RPMs, so just driving in a straight line will cause some driveline binding. You'll feel the binding if you try and turn the wheel. It's just simply the fact that the front and rear tires turn at slightly different speeds, and are locked together through the transfer case. The only "give" is when the pressure binds up, and the force makes the tire slip on the ground. That's what relieves the pressure. When on dry pavement, the tires have too much traction for the "binding force" to overcome. Something has to give, and if not the tires slipping, then probably the trasfer case chain will break first.
Old Dec 28, 2003 | 02:34 PM
Kristopher529's Avatar
Kristopher529
I am new to 4WD, but I also had this problem when I first bought my truck and was driving on extremely wet pavement, with some standing water. On the highway, it worked great. But when I started to park, I felt like I was riding a bucking bronco, since the tires still were new and had a strong grip on the road. I hope I didn't ruin anything up front now that I read this. I was told by the Ford Dealer that it was due to the inner outer tire spinning different speeds. Should I have my 4WD checked or is this normal when steering at slow speeds with it engaged?
Old Dec 28, 2003 | 02:51 PM
JeremyH's Avatar
JeremyH
You should be fine.....did you have it in low or high when on the wet roads? You should really only use 4hi on pavement if used at all.
Old Dec 28, 2003 | 03:08 PM
Kristopher529
Thanks for the post. I have only used it in 4WD-hi. I have not had any real mud or snow yet to test the 4WD-lo. Maybe next month.
