Aerostar Ford Aerostar
EGO not switching
Old Dec 17, 2003 | 11:34 AM
Drhy's Avatar
Drhy
EGO not switching
Hello,
I have a 1992 Areostar and when idoling it runs ruff and whats to stall. I had a diagnostic test done and it said EGO not switching so we replace the oxygen sensor but that did not help. we then replaced the air flow reader, etc.. we even replaced the plugs and the fuel filter still doing the same thing. Now my cruise control does not work not sure if one has anything to do with the other, I did check the fuse and it seems ok. Please help if you have any ideas..
Thanks
Old Dec 17, 2003 | 11:59 AM
tom_foreman's Avatar
tom_foreman
It sounds like you have a vacuum leak. Have you checked all the vacuum hoses?
Old Dec 17, 2003 | 02:49 PM
Drhy's Avatar
Drhy
Thanks for the reply Tom, I have not checked them But I will do that right now, Thanks
Old Dec 17, 2003 | 06:07 PM
Drhy's Avatar
Drhy
The hoses seem to be ok, any other ideas???
Old Jan 3, 2004 | 05:06 PM
Drhy's Avatar
Drhy
Tom, You were right it was a crack in a vacuum hose... Thanks so much for you help
Old Jan 4, 2004 | 06:29 AM
rlmdad's Avatar
rlmdad
Drhy,
Which vacuum hose did you find that was cracked? I'm wondering why a cracked vacuum hose would cause an oxygen sensor code to be pulled. I have a '92 3.0L XLT that's currently running fine, but I am interested in learning as much as I can about these types of problems.
Ron
Old Jan 4, 2004 | 06:45 PM
NorthernStar's Avatar
NorthernStar
Yes! Vacuum! Which one? And did you re-run the test to see if the code didn't reappear? I'm getting the same code and really really want to know IT ALL.
Old Jan 4, 2004 | 10:24 PM
Drhy's Avatar
Drhy
It was the vaccum hose that conects to the Trans. modulator valve. This was sending transmition fluid into the motor, and the motor inturn burning the tranny fluid. It was only around $30.00 for a new trans modulator valve and a new vaccum hose. Labour was just over 1 hour. So total it was just over $100.00. I was worried it was going to cost way more then that so I was very happy. Van has been running great every since. The dealership did re-run the diagnostic test and it was perfect.. By the way I don't think it would make a difference but mine is a 4.0L
Old Jan 7, 2004 | 01:24 PM
rlmdad's Avatar
rlmdad
Drhy,
Thanks for the info. I can see how if you were sucking trans fluid into the intake you'd get an O2 code and a very rough running idle. Definately something to look out for.
Ron
Old Jan 7, 2004 | 03:12 PM
Drhy's Avatar
Drhy
The good thing was it realy was not as expence as I thought it would be and now it runs like new..
Big_Walt
Feb 16, 2015 03:57 PM
grave00
Jul 23, 2013 08:56 AM
FchasE
Jun 8, 2011 06:19 AM
boaterdude83
Dec 1, 2010 04:47 PM
gdcook81
Bronco II
Mar 27, 2003 09:27 PM
