Sponsored by: Auxito
popping noise
Old Dec 16, 2003 | 07:14 PM
99monsterford's Avatar
99monsterford
popping noise
There is a popping noise when I turn into driveways and twis the truck's suspension. Anyone know what this could be?
Thanks, Shane
Old Dec 16, 2003 | 08:46 PM
JeremyH's Avatar
JeremyH
Check the anti-sway bar links on your truck. I have had a few sleeves in my links come loose and cause the entire link to come loose and make a popping sound like you describe.
Old Dec 16, 2003 | 08:50 PM
Racerguy's Avatar
Racerguy
Does it only pop when you have the steering turned as far as it will go?
If so, stick a dab of grease on each of the steering stops on the steering knuckle and try it again.
Old Dec 18, 2003 | 11:58 AM
99monsterford
I don't have to turn the wheel much at all. It sounds like it's coming from the rear end.
Old Dec 18, 2003 | 12:50 PM
JeremyH's Avatar
JeremyH
Make sure that your track bars are tight at both ends as well.
Old Dec 18, 2003 | 05:55 PM
LxMan1's Avatar
LxMan1
Is it a 2 or 4 wheel drive?
Old Dec 18, 2003 | 07:49 PM
99monsterford
It is a 4 wheel drive. I will check my sway bar. I don't know what the track bar is.
Old Dec 18, 2003 | 08:59 PM
JeremyH's Avatar
JeremyH
Track bar attaches to the frame and the axle......it is what keeps the axle from moving laterally.
Old Dec 18, 2003 | 11:21 PM
LxMan1's Avatar
LxMan1
It should have control arms like a 2 wheel drive. The center section is mounted solid and uses CV type joints on the axles. Chack the ball joints and tierod ends.
Jimmy
Old Dec 18, 2003 | 11:50 PM
Racerguy's Avatar
Racerguy
If the noise is in the rear does it pop more than once if you drive around in a tight circle?
Old Dec 19, 2003 | 06:45 PM
ssteve's Avatar
ssteve
I had a popping noise in my 2001 supercrew. The dealer said it was due to the slip yoke in the drive line. He cleaned and greased it and it stopped for a few days. He also cleaned my wallet of $100. May want to check it out and maybe grease it yourself.
Old Dec 19, 2003 | 10:35 PM
JeremyH's Avatar
JeremyH
Well, it doesnt sound like a driveline issue.......he didnt mention anything like it happens more frequently as the vehicle's speed increases. And actually....$100 isnt bad to grease the u-joints and yoke (if that's what he did).
Old Dec 20, 2003 | 06:21 AM
aldridgec's Avatar
aldridgec
Maybe the springs shifting. I've heard of a few guys having this problem including me.
Old Dec 22, 2003 | 01:38 PM
99monsterford
If I turn in a tight circle it won't pop at all unless I go into a driveway or on some kind of incline. I also notice it more when I am turning right. I have a 12" suspension lift on the truck with 10" lifted springs and 2" blocks. I never had the problem before it was lifted. Does this sound more like shifting springs or a driveline problem?
Old Dec 22, 2003 | 03:17 PM
Fordtrucktexan's Avatar
Fordtrucktexan
I have Febtech 3.5" lift spindles on my '97 F-150 and used to get the same popping noise until I sprayed some Supertech White Grease on the ball joints. It's a 2wd though. The guy who aligned the front end swears it's a body movement noise.
