Sponsored by: Kumho
clicking noises from steering
Old Dec 16, 2003 | 07:19 AM
BigShelby's Avatar
BigShelby
After I completed some engine bay beautification I am experiencing a single click or knock when I turn the steering wheel left or right. This same noise is also noticable when going over a rough surface. Following the engine bay washdown I lubed the chassis and u joints. I seem to think the noise is coming out of the steering gear box or some related linkage. What are your thoughts? Thanks
Old Dec 18, 2003 | 12:35 PM
Gulf001's Avatar
Gulf001
I am in the process of replacing my steering gearbox because of a noise like this plus it shakes at higher speeds and tends to wander, especially over a washboard road. There is also alot of play in it. But you probably won't notice if it has play in it until you take it off the vehicle. Hope this helps, Chris
Old Dec 18, 2003 | 12:36 PM
Gulf001's Avatar
Gulf001
p.s. I am replacing it on a 97 f-250HD with 5.8, 2wd, and auto transmission.
Old Dec 18, 2003 | 05:37 PM
BigShelby's Avatar
BigShelby
BTW if you didn't notice in my signature it's 73 f100 2wd.
Old Dec 19, 2003 | 12:04 AM
MustangGT221's Avatar
MustangGT221
Put a jack under the axle and lift the front tires off the ground. Either turn the wheels by hand under the truck, or have someone else turn them for you...see if you can see/hear anything. Check ball joints too.
DieselCamper
May 8, 2016 06:29 PM
don123
Dec 23, 2015 09:25 AM
synergy141
6.4L Power Stroke Diesel
Sep 8, 2015 07:30 AM
Jack-o
Jun 10, 2011 06:10 AM
Dave85zxt
Jan 7, 2004 04:16 PM
