steering column converison
Old Dec 15, 2003 | 02:19 PM
dhitman's Avatar
dhitman
HAVE 1969 F100 390 4SPEED....WOULD LIKE TO INSTALL TILT WHEEL.ANY IDEAS AS TO WHAT WILL FIT.
Old Dec 15, 2003 | 05:59 PM
sparky's Avatar
sparky
Anything up to 79, as long as it is 2wd to 2wd, but you will have to "convert" the wiring to match your truck.
Also I think that tilt was only offered in 78-79.....but I have been wrong before
Just noticed you have a 4 speed.........those tilt manual columns are kind of rare I beleive....so you may have to modify an auto column.
Old Dec 15, 2003 | 06:18 PM
BB's Avatar
BB
Yes 78-79, I didn't even know thay made a tilt manual column. If your 69 has the Bendix ps box you're screwed 'cause the column is longer too. If you have the Ford ps or manual box you're ok.
Barry
Old Dec 15, 2003 | 06:24 PM
sparky's Avatar
sparky
Barry
Maybe they don't
I guess that could be why they are so rare
Old Dec 15, 2003 | 06:27 PM
BB's Avatar
BB
You might be right Sparky, I'm trying to figure if I got those column lengths correct, having a brain fart.
Barry
Old Dec 15, 2003 | 06:51 PM
mk's Avatar
mk
I think what you meant to say Barry was that the Bendix p/s and the Ford manual boxes are the same size and the Ford p/s box requires a shorter column Which is correct. The 78-9 tilt columns work with the 68-79 Ford p/s box.
mike
Old Dec 15, 2003 | 07:06 PM
BB's Avatar
BB
Thank-you mike. Yeah yeah, that's what I mean't to say.
Old Dec 18, 2003 | 07:35 AM
dhitman's Avatar
dhitman
Thumbs up thanks to all
was able to find tilt column(automatic)on a79 f150.
with only few mods,remove gear selectplate,match wiring,trim lower cover(came with tilt) works great,Thanks for all info.
Old Dec 18, 2003 | 12:44 PM
hydrosmith's Avatar
hydrosmith
One further question that is maybe a little ignorant, do the colums from a Ford van work in a truck?
Old Dec 18, 2003 | 02:45 PM
73Custom's Avatar
73Custom
They were made, but are very rare. I've heard of 2 through this site, but never laid eyes on one...
Marty
Old Dec 18, 2003 | 06:46 PM
mk's Avatar
mk
I don't think the van column will work, but they are great for cannibalizing parts from as the tilt mechanism is the same. The collar has to be swapped or modified, however, as the ign switch is on the van column. The turn signal switches should interchange on all 78-86 pickup and van tilt columns as well.
mike
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
