'65 4x4 conversion
Old Dec 14, 2003 | 06:51 PM
jwalsh's Avatar
jwalsh
Question '65 4x4 conversion
I have searched this site and come up empty. Is it possible to take a perfectly good '65 2wd and put the transfer case, shafts, steering etc from a '65 4wd under it and have it work?
Thanks in advance
Old Dec 15, 2003 | 05:13 AM
FordBoypete's Avatar
FordBoypete
Thumbs down Not the really Best of Ideas
JWalsh
No, not as a bolt up conversion. This is to say really anything is possible for people willing to sacrifice enough, but at some point that can become a foolish exercise.
There are major differences in:
Frame, Steering Box & Column, BAsic Suspension, TWIN I-Beam front Axle w/ Coil Springs vs Live SINGLE Front Axle on Leaf Springs, the list goes on & on.
If you want a Slick 60s 4X4 you have 2 real options. You can Get a 60's 4X4 or get a later 4X4 chassis & work at converting a 65-66 style body to fit that. ALthough id you have a running driving complete 4X2 now, you might want to think about it some before you whack it apart to create a 4X4 out of it's body.
FBp
Old Dec 15, 2003 | 08:59 PM
5.0L 44GPW's Avatar
5.0L 44GPW
Early 4x4
Here is how I did the last 65 F100 4x4,
1-- 65 F100 short box 2x4
1-- 1979 front F150 4x4 clip cut 12 inches back of the front cab mounts.
Measure your wheel base to make sure you get the wheels back in the wheel wells where they belong when you are finished.
Clip off the 65 2x4 frame off at the front cab mounts and slide the early frame right into the new frame its a very tight fit.
I slide mine in about 12 inches, you can bolt them together and weld along top and bottom. The front cab mounts are the same the back cab mounts are the same since they are on the old frame, bed mounts are the same.
Use the 77 steering col and steering shaft and bingo you got a great driving great looking 4x4 with power steering and disc brakes. Of coarse there is a little more to this project but its fairly straight forward .
I have some great pics of the project but I need a scanner to get them on the computer I will work on that.
Old Jan 7, 2004 | 02:04 PM
TremecGT's Avatar
TremecGT
Im planning on doing a similar f250 swap, now could you use the entire frame and fab the rear cab mounts? Just curios why you cut the frames. Thanx for the info, oh and that is the nicest uni i have ever seen! great stance!
Old Jan 8, 2004 | 08:53 AM
5.0L 44GPW's Avatar
5.0L 44GPW
THANKS tremecgt
The only reason I cut the frame was the bed mounts, they are alot different than the early bed. I probably could have work around the mounts but the other thing, was I used a late model long bed frame and was building a short bed 65
Ezridr65
Jul 11, 2015 04:11 AM
nerksa
WTB - Parts & other
Mar 22, 2015 09:42 PM
tobygo67
Nov 6, 2014 09:35 AM
-mywheels-
Apr 1, 2014 08:51 PM
lance65
24
Nov 5, 2012 04:27 PM
