Sponsored by: Real Truck
Electrical nightmare
Old Dec 14, 2003 | 06:41 PM
Larry33's Avatar
Larry33
I've got a 1998 powerstroke F-250 4door, 4WD with 47K on it. I love the truck. I bought it used about 10 months ago and had some trouble initially with the interior lights not wanting to go out. Recently the interior lights started coming on by themselves, the heater motor powered up and I heard a buzzing noise coming from, as it turns out, the #1 relay in the fuse panel under the dash. It had killed the battery and I pulled the relay. I have no interior lights or running board lights with the relay out but everyhting else works fine. I replaced the relay but had the same problem.
Yetsreday while driving along the highway (still with the relay out) The overdrive light started flashing on the shift lever and the cruise control quit working. This issue seems to have repaired itself but I obviously have a serious issue somewhere. Any ideas? (I'll get it in to the shop as soon as I can but it may be a few weeks)
Thanks for anything anyone might have for suggestions.
Larry
Old Dec 14, 2003 | 09:11 PM
02superstroker's Avatar
02superstroker
i am not sure as to what you could do... but you say it is a 1998? Is it a superduty or the old body style?
Old Dec 15, 2003 | 04:19 PM
Larry33's Avatar
Larry33
electrical nightmare
yes, it's a superduty
Old Dec 15, 2003 | 05:10 PM
emtabmm's Avatar
emtabmm
Saw quite a few strokers with the green grunge under the underhood fuse box, get a mirror an check all the leads going in....
Old Dec 15, 2003 | 07:21 PM
Larry33's Avatar
Larry33
Thanks, I'll give that a try. Sounds like it might be something like that as the interior goes haywire then settles down for awhile.
Larry
Larry85355
Dec 10, 2025 07:28 AM
tufftruck
Nov 10, 2016 12:54 PM
Flargen
May 17, 2016 03:08 PM
JJ1983
Electrical Systems/Wiring
Jul 31, 2015 07:30 AM
Mad_max
Jul 5, 2012 06:12 PM
