Offroad & 4x4
off road driving tips
Old Dec 13, 2003 | 08:49 PM
muscletruck7379's Avatar
muscletruck7379
hey, as some of you might know i got my bronco going a few weeks ago and now that i've gotten used to what its like on road i would like to try it off road, any good off the road driving tips other thatn take it in baby steps(already know that) but all that i've don so far is go out and play in about 4" of snow.
Old Dec 13, 2003 | 11:46 PM
85351ho's Avatar
85351ho
if it starts hoppin, let out of the gas(unless you liekc arnage)
uhhh??? keep your thumbs on the outside of the steerin wheel
if your in doubt, hold it to the floor
Old Dec 13, 2003 | 11:53 PM
fishmanndotcom's Avatar
fishmanndotcom
first you gotta find something a lil more challenging than 4" of snow! I got a nice mudhole back behind my house if you want some good experience....don't believe me? ask 85351ho.....broken yokes suck don't they?
just remember the more you break the more you replcae and the stronger it will be. Plus you will know your truck realy well
get the biggest tires you can and the smallest lift. lower center of gravity will help you always!
cut your tires....no matter what kind they are
have fun
one more thing, as I once heard from a good friend of mine.....Rev it till the valves float...Sidestep the clutch...and steer!
-jason-
Old Dec 14, 2003 | 12:11 AM
swann79's Avatar
swann79
Trust me... biggest tires aren't always the answer... everything depends on your weight to tire size ratio and what you're up against.
Getting spanked by an underpowered '74 bronco with stock size tires made me a believer.
But I'll get 'em someday...
Old Dec 14, 2003 | 01:40 AM
Texan1983's Avatar
Texan1983
well for a big heavy truck buy the bigest tires you can fit! or in my case i buy the biggest i can afford.
Old Dec 14, 2003 | 07:40 AM
71_4x4_390's Avatar
71_4x4_390
Tips? Have a good plan in case things go wrong, see my Bad Weekend post from today. Take with you all the tools you can carry, and as a general rule of thumb go with another 4x4. I almost got screwed this weekend, you should never venture into parts unknown alone.
Tools
Shovels
Hi-Lift jack
Some planks of wood for shoring
Spare parts, belts tubes etc.
Big rubber boots
Cell phone!
Water, for you and the truck
Extra gas tank
Winch... my next big purchase
If you think you might need it, take it. Stay away from water, unless you know exactly how deep it is. I got fooled once in my Jeep on the water/mud trap. If you come onto a section of terrain and it looks iffy, get out and walk it through, plan your path and don't get yourself to the point where you can't get out the way you came in unless you know there is an exit. It's fun, everyone gets stuck (me more than most), and like most hobbies, is expensive if your not careful.
When your all done, wash and lube the suspension of your truck, unless you like changing U-joints.
Hope this helps you.
Old Dec 14, 2003 | 02:22 PM
muscletruck7379
out here we have the bijue (i think its spelled that way) its a creek bottom that is trees, sand, and a bunch of hills about 20-30 feet tall, about a 70 degree angle, but i also plan on taking it to the mountains, i've heard of the whole thumbs out of the wheel in an earlier post, and thankfully broke myself of the habit, and wheelhop is a major issue cause i have already discovered that the bronco is infected w/ that terrible disease, but i am working on a cure, i will most likely be going with two other buddies and either a *******, or a gmc tahoe, and i have most of the items on 71_4x4_390's list, just need to do some packing, and i am currently trying to get my fingers around some 31x10.50's not very tall , but much wider than the stock size
Old Dec 14, 2003 | 09:10 PM
B C fx4 Level II's Avatar
B C fx4 Level II
Blasting through deep water looks good on T. V. But it's not a good thing to do in the real world. Water does not mix well with internal parts..
The Slower through deep water the better (in most normal circumstances)
Old Dec 14, 2003 | 09:36 PM
Txquadhunter24's Avatar
Txquadhunter24
Judge your Angles Right in your Bronco, They are top Heavy lifted or not. Can't count the times my Butt had a tighter bite on my seat then I did due to angles. I always hated the Iffy places. Most of ours end up a cake walk and the Places that look easy is a bottomless pit.
Like staed above always have backup with you no matter how many times you've wheeled the place and didn't get stuck, There is always someone with a bigger truck who sneaks in holes and leaves ruts for others to find. That'll be when your alone. I've been a guilty of my boggers opening up once small hole to pits. Really when I've had to drag out Drowned out or downed trucks.
Since we run creeks quite a bit the water crossings in those are the ones to watch. Really if it's dry because if it's still holding water thats usually a maiin channel and will be deeper then they look.
Old Dec 14, 2003 | 11:53 PM
JeremyH's Avatar
JeremyH
HeHe.........this sounds funny. 53's and a 1" lift!!!!!!
Old Dec 15, 2003 | 09:42 AM
fishmanndotcom
well this being a technical site i was assuming that whoever reads this has the common sense to perform the appropriate mods to their truck when getting bigger tires. Sorry for the assumption....i guess we all don't have common sense
-jason-
ps....one thing i did forget and is extremely important; take spares with you! mainly drivetrain parts b/c in the least you could be towed out if it at least rolls! you can make do w/o an alt belt or all 4 shocks!
Old Dec 15, 2003 | 01:16 PM
KJKozak2's Avatar
KJKozak2
If you're going out on mud trails, I'd have to agree that biger tires are better. Every time I got stuck it was my difs bottoming out. Only bigger tires will solve that.
Bring a tow strap, too.
Kevin K.
Old Dec 15, 2003 | 01:25 PM
Texan1983's Avatar
Texan1983
i wish i could fit 53" with only 1" lift. that would be awesome. but that is what you want... biggest tires small lift and alot of fender trimming. i plan on 38" with only 4" of lift in the future.
Old Dec 15, 2003 | 01:41 PM
MustangGT221's Avatar
MustangGT221
Well there are always exceptions...depends on what kind of off roading your doing, suspension travel is also important.
Old Dec 15, 2003 | 05:45 PM
muscletruck7379
oops, sorry, but i forgot to tell you, the creek is dry, but the water info is good for future reference, and the only problem is that it is me that has the most capable 4x4 in our group, but its not likely to get stuck in the bijou, and even if that happens we will go get the superduty or a tractor, like what i said its mostly sand and hills.
