300 6 compression
Old Dec 13, 2003 | 07:27 PM
bigblocksix's Avatar
bigblocksix
300 6 compression
alright guys im rebuilding a 84' 300 straight six, stock head, stock replacement pistons, i want to get some more compresion by having the head milled, how much compression could i use and still run cheap 87 octane gas, how much would i mill off the head to acheve this ?
Old Dec 13, 2003 | 11:25 PM
fordeverpower's Avatar
fordeverpower
your basic .010 mill job won't do much. You can run 87 0n 10:1.
Old Dec 14, 2003 | 04:34 PM
bigblocksix
compression
i decided on decking the block not the head, but im kinda lookin for an exact figure here to tell the machine shop
Old Dec 15, 2003 | 08:29 PM
ftwfred's Avatar
ftwfred
The amount of decking for the block will be determined after it is fitted with the Crankshaft and new piston/Rod combinations...(Gotta see how close to the top they are coming)
the Head should be milled at least .010 to square it up anyway..
with the stock pistons you could probably take up to .080 off with no problems..
Your BEST BET to raise the compression to a point that will still run on pump gas is to find a CYLINDER HEAD fron a 240 and use it.
Get a good 240 head, Cut it .010 to square it up and yer ready to go!!!!
ftwfred
ftwfred
Old Dec 15, 2003 | 09:29 PM
f100guy's Avatar
f100guy
yeah but you will need to get the 240 head ported and pollished since the 240 did not breathe very well
Old Dec 15, 2003 | 11:42 PM
bigblocksix
compression
well i decided i am not going to deck the block as it is already assembled, i am however going to deck the head for more compression, i would like to know how much to mill off the head of my 84 300 6 for optimumum compression on 87 octane gas
thanks
Old Dec 16, 2003 | 09:26 PM
74crwcb429hibPS4spd's Avatar
74crwcb429hibPS4spd
I thought 9.5:1 was the highest you could go on 87 octane.
Old Dec 17, 2003 | 05:34 AM
ftwfred's Avatar
ftwfred
LOL the 240 head breathes EXACTLY like the 300 head
Shave the 300 head WITHOUT porting it and you are still in the same boat!!!!!!
ftwfred
forss
Aug 2, 2012 09:11 PM
59flatbedford
Mar 20, 2007 05:33 PM
385seriesHemi
Nov 14, 2006 09:37 PM
EXOPAR
Jan 30, 2003 11:17 AM
fordtruckin
Mar 31, 2002 12:55 PM
