Ok, here I go again. If you run part synthetic oil (valvaline Dura Lube) in a PSD and decide to switch back to Regular oil (Rotella) will you be in trouble as far as damaging seals? Ive been told that synthetic oil adheres to seals and when you switch back to regular oil you could have a problem.
I wouldnt worry about it,the valvoline durablend is probably only 25% or less of synthetic so if you want to go back to regular Rotella-T by all means do so.There will be no harm.
