brake trouble
Old Dec 12, 2003 | 05:37 PM
blueovalfan's Avatar
blueovalfan
brake trouble
I have a 89 F-150 4X4 . my problem is that it keeps blowing fuses for the brake lights , I have follwed the wires from the brake lights to the cab, I did not find ant bad wiring . I have replaced the brake light switch. Still have the problem , anyone have any other ideas? Thanks for any info.
Old Dec 12, 2003 | 07:54 PM
mcanik's Avatar
mcanik
Did you check the light sockets?
Old Dec 12, 2003 | 10:31 PM
sandrat's Avatar
sandrat
What else is on that fuse?
Old Dec 12, 2003 | 10:38 PM
blueovalfan
emergency light ..is i think
Old Dec 28, 2003 | 08:52 PM
kb2vrm's Avatar
kb2vrm
This is my first posting here - I had an 82 Bronco with the same problem . I eventually found that the fuse was blowing as the shifter passed through reverse on the way to drive .( My backup lights had not worked for a while either) .It turned out that my neutral safety/backup light switch on the transmission was bad .
Old Dec 28, 2003 | 09:05 PM
fordin K's Avatar
fordin K
does it blow immediatly after hitting the brakes with the new fuse in ? or does it take a long hold or several brake cycles ? if it goes instantly, you know you got a short. if slow, you got high resistance. could be socket corrosion, bad connection, got any stretched wires leaning on metal ? all it takes is a pinhole hit...
Old Dec 29, 2003 | 06:52 PM
kb2vrm's Avatar
kb2vrm
my problem was the nuetral safety switch on the trans . The brake lights and the backup lights used the same fuse and when the shifter hit reverse it would short out and blow the fuse ( not every time but that was the problem and it had nothing to do with the brake lihgts accept that they shared the fuse ) that was my truck yours may be an entirely different fix .
Old Jan 1, 2004 | 09:42 PM
blueovalfan
I think ( and hope) I found the problem. On the brake light switch, the wires had a bad bend in them . I replaced the plug in and have not blown a fuse yet . I has been 3 days so far so good
Thanxs for all the info, it was the first time i have ever posted anything on here.
4x4superduty88
1997 - 2003 F150
Nov 9, 2010 05:28 AM
TRX450R
Jun 29, 2007 12:51 PM
jad4
Nov 7, 2005 09:27 PM
boosdad
Aug 29, 2003 10:27 AM
bossmanbef
All Things Towing
Apr 5, 2003 06:36 PM
