Junkyard with locator is best bet but, I have a question. Are you talking about the what I call the tree or the stand that bolts to the frame and the engine mounts set down into? I have a couple of trucks out back and would be glad to check just let me know.
In my notes, I have that the perches for the 302 and 351W are the same but then there is a different set for the 351M and 460. One set does not cross to the other.
Ford SHOULD still have them. Go in and tell the parts guy you need them for a 97 F350.
If all else fails, try one of the online Ford parts stores, like 1stford or such. They do have them listed for a 91 still... Just make sure you tell the guy you need them for a F250 or F350, he can't get them for a F150 because they don't exist for a F150 in the computer.
I bought a set from L and L and as far as I'm concerned they were worth every cent. Bout 100 bucks, at least when I got mine, with a lifetime warranty.
Hey guys when I bought my 84 F-150 SB it had a 460 in it and it now has a 302 sitting on the 460 mounts. But because I had them I tried a pair of 88 Crown Vic wagon motor mounts & they worked, so thats how my 302 is bolted down. I have three more pairs, 2 pair off 302's & they wouldn't match the frame holes & I tried a pair off a 79 400 BB but they were to tall
so I just put the 460's back in & used them. Be aware that if you go to take a set off a 90 or newer truck getting the rivits out & the mounts off is a lot of hard work.
