Sponsored by: Auxito
trans problems
Old Dec 11, 2003 | 08:06 PM
a500ponies's Avatar
a500ponies
Angry trans problems
the transmission in my my 1997 f150 4 by4 4.6 auto just started to whine in first gear when i take off it also shudders when down shifting from 4 to 3d you can feel it dropping down at aboult 40mph at 70000kms any ideals it almost out of warrenty so before i bring it in has any one else had the same problems also when you have to air conditioning on i get fumes from cars in front of me and some times the air blows out the defrost for a few seconds instead of the vents .. control valve maybe it also pings when i put it in 4 high but gets 21.3 on the highway at 60mph ..a few bugs but one hell of a good truck
Old Dec 12, 2003 | 08:23 AM
LxMan1's Avatar
LxMan1
Has the fluid ever been changed??
The fumes are because on any setting except Max A/C, air is drawn in thru the cowl so any fumes that you drive thru, may be sucked in there.
I would check the vacuum line going to the vacuum canister in the passengerside fenderwell, I'll bet under hard acceleration is when it switches from the vents to defrost. If the line is cracked, the canister will not hold vacuum on the controls and when accelerating (the vacuum drops) the canister can not keep vacuum on them and the defrost position is the default position so that you can always keep the window clear.
I don't know why it would only ping when in 4x4.
Jimmy
Old Dec 12, 2003 | 11:15 AM
a500ponies's Avatar
a500ponies
Unhappy transmission
no i havent changed the fluild in the trans yet but that wouldnt cause it to whine and the vent problem happens mostly at astop lite with the air on im going to the dealer soon so i will let every one know what s wrong thanks i wonder if they will fix the paint thats peeling on the roof of the truck
Old Dec 12, 2003 | 11:21 AM
LxMan1's Avatar
LxMan1
I think that they might if you have the bumper to bumper extended warranty.
Old Dec 12, 2003 | 04:52 PM
geoaigel's Avatar
geoaigel
Fluid change isn't crucial on these transmisssion. Changed mine at 125k miles, all 14 quarts of it. Have 170k miles on it now on the second batch of trans fluid. Transmissions are contained systems, unlike an engine, there is no contamination coming in from the outside. If you use a very good fluid like Ford does, they are practically maintenance free.
George
Old Dec 12, 2003 | 10:28 PM
LxMan1's Avatar
LxMan1
Not from what I have read on here from many people.
Yes it is a closed system, but as clutches wear, the debris enters the fluid. Todays filters are more of a screen than a small micron filter. This debris gets into the valvebody and starts sticking valves. Todays valvebodys are alot more complicated these days with electronic shifting, lock up converters and OD. Every 30,000 to 35,000 miles is a good time to change it.
Jimmy
Old Dec 13, 2003 | 12:10 PM
a500ponies's Avatar
a500ponies
Talking transproblem
the dealer said no to the paint and its peeling on the roof and rusting in the 3door seam but today it was 15below zero here and the wife took the truck to work on the way the re the check engine lite flashed six times and stayed on so i called the dealer and he said its 80.00 to scan the compulter and itold him i have bumper to bumper warenty and he said thats ok as long as its warenty related and told me l mite have to pay the80buck if thats so im trading that puppey on a lighning at least then ford will be fixing that one free .
Old Dec 14, 2003 | 02:26 PM
LxMan1's Avatar
LxMan1
Sounds like you need a new dealer!!!!!
Old Jan 30, 2004 | 10:37 AM
a500ponies's Avatar
a500ponies
well i have to give the dealer in sudbury credit where its due they charged me 280.00 to get the engine lite off they said water got between the n 1 plug and wire so they cleaned it . put some desal greese on the plug .but wound not change the spark plug wire..they fixed the leaky oil cooler lines on both the engine and transmission.. they could not here any whine from the trans mission they said that was normal ..when i picked the truck up the interior lite was on ...so they also fixed the switch for the interior lite .. but broke the clips on the door panel . the clips are not replaceable . the panel is one piece . so now they have to replace that panel also ..and the sad part is i think they dont realy give a **** because they also treated several other peo ple there the same way as me . they also recomended i change the trans fluild at a cost of 250 bucks ..i just turned 70k on the truck ..and the warenty is now over . and thats the last time i will ever bring my truck back there ,..the sevice rep favorite words were.. oh thats not under warrenty thats not covered etc etc i just had the lube shop down the steet from the dealer .. change the trans oil and filter for 110 bucks ..a far cry from 250 plus tax ..
Torky2
Escape & Escape Hybrid
May 21, 2012 11:13 PM
drpepperinacan
Dec 23, 2010 01:40 PM
Shoob36
Nov 11, 2010 07:53 PM
miker67
Sep 11, 2009 10:04 AM
bettendorf
Feb 25, 2004 06:09 AM
