vacuum line disconnected
Old Dec 11, 2003 | 07:35 PM
sysco's Avatar
sysco
Question vacuum line disconnected
4wd won't engage. I found the vacuum line disconnected, but I can't find where it disconnected from. Can soneone please tell me where it connects.
Old Dec 11, 2003 | 07:48 PM
Ken00's Avatar
Ken00
What year is your truck? Were did you find a disconnected vacuum line?
Old Dec 12, 2003 | 01:52 AM
sysco's Avatar
sysco
96 Ranger - the line is connected to the front differential but the other end is connected to nothing.
Old Dec 12, 2003 | 11:18 AM
amp17757's Avatar
amp17757
I have never checked out a RANGER system specifically. But, I could hazard a guess. Most vacuum controlled 4WD switching systems have ... uh ... SWITCHES ... duh! (feeble attempt at levity). If the end that you found CONNECTED is on your front dif, then the other end MIGHT go to a nipple on the transfer case??? Or, of you locate a "bundle" of vacuum lines, look at them very closely. One of them might have a "bare nipple", which is where your loose line is supposed to go???
Old Dec 14, 2003 | 09:49 AM
amp17757's Avatar
amp17757
Question
Hey "sysco", have you had any luck?? Where I am, it's snowing like a !@#$%^&*()_+. Where are you?? Is it snowing?? If yes, I hope you found out where that vacuum line is supposed to be.
Old Dec 14, 2003 | 06:37 PM
rclarke's Avatar
rclarke
If my memory hasn't failed me I believe the solenoid valves are located on the passenger side of the firewall.
matty169
Apr 28, 2025 06:42 AM
cclgeo
Mar 7, 2017 10:31 PM
Hussler
Jul 1, 2015 11:20 PM
390Highboy
Jan 1, 2014 07:53 PM
bio-d
Jul 18, 2008 12:51 AM
