Compressor side temp?
Old Dec 12, 2003 | 10:46 AM
resqdawg3's Avatar
resqdawg3
I seriously think that if you upgraded to a quality bar and plate FMIC, and maybe a larger diameter IC piping that you would definately seem some quality gains in both performance and lower IAT's.
Old Dec 12, 2003 | 11:40 AM
cdtruckn's Avatar
cdtruckn
Air to air is the best right now, but if a guy would put a A/C evaporator on the discharge side of the air to air in a box and tee
the A/C system then you would have a cooold intake with very little money and would be easy do do.
All of the 6.0 have air to air after coolers and depend on ambient air temp to cool(air to cool air) (after the turbo)
The inter coolers are not as good because thy used the engine radiator water to cool the air down to the engine temp. (internal air cooler) like dodge Cummings.
Old Dec 12, 2003 | 12:08 PM
Hjudge49's Avatar
Hjudge49
The Volvo diesels on my boat use a water to air system (using salt water before it gets to the heat exchanger to cool the engine coolant) very efficient. Too bad there's no steady source of nice cold water in the trucks. Might I suggest using a probe type meat thermometer to record the temps from both sides. The ones with the wire that feeds the little timer/thermometer thingy.
Old Dec 12, 2003 | 12:15 PM
cdtruckn's Avatar
cdtruckn
Ya, I just can't get my dually to float.
Old Dec 12, 2003 | 12:19 PM
Hjudge49's Avatar
Hjudge49
Frightening thought! The change from internal combustion to steam does interesting things to connecting rods. I cracked a manifold on a mercruiser once at about 4500 RPM. It was interesting to say the least.
Old Dec 12, 2003 | 12:58 PM
cdtruckn's Avatar
cdtruckn
Don't forget expensive too!!
Old Dec 12, 2003 | 01:32 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Interesting in a catastrophic way
Old Dec 12, 2003 | 01:58 PM
$trokin60's Avatar
$trokin60
tim look on bankspower.com I believe they are running an air to water inntercooler on the sidewinder dakota with the 5.9 cummins engine I believe that when they ran it at the salt flats they had it filled with ice water here is a number for a power consultant at banks that can help you out with this question he has helped me out on numerous occasions he will even conect you with an engineer if he doesnt know the answer 1-800-438-7693 and ask for james joyce hope this helps they also have nos kits for some of the imports that spray nos on the inntercooler to bring the temps down instead of in the intake
Old Dec 12, 2003 | 04:48 PM
IB Tim's Avatar
IB Tim
very COOL
Thanks
Old Dec 12, 2003 | 05:10 PM
emtabmm's Avatar
emtabmm
But would this be greater than the loss experienced while running the a/c?
Old Dec 12, 2003 | 06:22 PM
cdtruckn's Avatar
cdtruckn
My a/c is on every time you use the heater . I don't know y ford did that but every time you turn on the climate control the a/c pumps on, it only takes a couple of hp's to run, so the gain would be a big plus.
Old Dec 12, 2003 | 07:30 PM
IB Tim's Avatar
IB Tim
I thought it was only supposed to come on when the defroster is activated
Old Dec 12, 2003 | 08:07 PM
  #28
cdtruckn's Avatar
cdtruckn
that's the way it should be, but its on any time you turn the selector from the off position, kinda sucks
Old Dec 14, 2003 | 07:32 PM
  #29
emtabmm's Avatar
emtabmm
Only positions it does not run on is heat (floor)only or vent(dash) only....
Old Dec 14, 2003 | 07:44 PM
  #30
IB Tim's Avatar
IB Tim
OK good to know, when did they change it form the defroster one.
Or have I been incorrect all this time.
thought it was the same on all Fords
