Doggone ignition control module !
Old Yesterday | 10:10 AM
Tommy_Toohigh's Avatar
Tommy_Toohigh
3 month old/new ICM from a box with Motorcraft printed on it starting to fail?!?
Heading to Eastern WA, (80's) it started to stumble/not take throttle smoothly.
~~Any quick fix?? Tips?~~
Yes, I applied heat goo from the electronics store, didn't overtorque, etc...
I'll have to get back to the Seattle metropolis Sunday on a (very likely) stop-N-go I90 traffic nightmare :-(
Old Yesterday | 11:43 AM
JimsRebel's Avatar
JimsRebel
Is this the ignition module on the side of the distributor? A computer controlled ignition?
Are you running the original stock coil, or did you upgrade it.
https://www.ford-trucks.com/forums/1...150-4-9-a.html
Jim
Old Yesterday | 12:43 PM
Tommy_Toohigh
Yes, on the distributor
Original coil. ICM on the distributor.
So, retrofit a remotr one? And new coil?
At a festival, no tools, but I have resources
Oh, 86 EFI 5.0
Old Yesterday | 01:52 PM
JimsRebel's Avatar
JimsRebel
It's usually heat related. Figuring a way to cool it might help. Maybe a blast tube, but that wont help in stop and go traffic.
Disconnecting the spout connector will take to computer out of the picture, running in fixed timing, about 10 degrees.
But it won't help if it still gets hot.
Good luck, Jim
Edit, if your coil is original, I would not touch it. A New Coil might be lower quality.
Old Yesterday | 08:06 PM
BigBlue2's Avatar
BigBlue2
If heat is the issue plan to travel as late in the day as possible and that should be better for traffic as well.
'84 F150
Dec 5, 2011 11:09 AM
griffingt
Dec 2, 2010 09:28 AM
Superdave
42
Nov 21, 2010 02:00 PM
ptalbert33
Aug 4, 2010 06:35 PM
73ford
Mar 9, 2002 08:01 PM
