Clarification - please
Old Dec 1, 2010 | 02:43 PM
griffingt's Avatar
griffingt
Are the PIP, pickup coil, distributor stator referring to the same part? Are the TFI and ICM (ignition control module) the same part? Thanks
Old Dec 1, 2010 | 03:12 PM
rla2005's Avatar
rla2005
PIP, pickup coil, distributor stator are referring to the same part. The TFI and ICM (ignition control module) are the same part as well.
Multiple names for the same thing just to confuse the civilians.
Old Dec 2, 2010 | 04:52 AM
griffingt's Avatar
griffingt
Thank you! Now maybe the kids at Autozone won't run and hide when they see me coming.
Old Dec 2, 2010 | 07:53 AM
rla2005's Avatar
rla2005
Be very careful of "remanufactured" distributors. Many times it has been reported it took a few tries to get one with a good PIP in it. If you are going down that path.....
Old Dec 2, 2010 | 09:28 AM
subford's Avatar
subford
The PIP is a sensor mounted in the stator and the stator is mounted inside the distributor.
The pick-up coil was used from about 1975-1985 in the DuraSpark II Ignition system and was replaced by the PIP sensor when they went to the EEC-IV Ignition system.
There is no pick-up coil in the PIP/Stator.
The TFI is how a ICM is made.
PIP: Profile Ignition Pickup, Provides crankshaft or camshaft position information for ignition synchronization.
TFI: Thick Film Ignition. An ignition module comprised of a custom integrated circuit, Darlington output device and associated thick film integrated components.
ICM: Ignition Control Module, The module that controls the ignition system.
OPEN BOWL 1985-1992:
From 1993-1996~:
Pick-Up coil 1975-1985:
nards444
Oct 29, 2015 09:56 AM
Vince79vette
Dec 11, 2014 09:24 AM
e-tek
Dec 14, 2009 08:04 PM
Vanet
16
Oct 12, 2009 03:42 AM
Sam_Fear
Aug 14, 2008 09:53 AM
