First: Can you get me the part #'s for the clutch *** and new flywheel. Is the clutch sold as an ***. ( disc and pressure plate)
Second: Does your shop put a new clutch ***. on an old or unsurfaced flywheel?
The reason for my concerns is I had the rear main seal replaced
and they had to replace the clutch ***. because it was contaminated with oil. I told them that I wanted the flywheel repalced and not resurfaced because the truck only has 1000 miles on it. Now the clutch chatters upon engagement. I looked over the invoice and can not find the New flywheel on there.
Any help would be great.
