Pedal Assembly Bushing Conversion?
Old Jun 12, 2026 | 04:53 PM
TheAngryTexan's Avatar
TheAngryTexan
1st Gear
Good afternoon y'all. Long time lurker, first time poster - that being said, I hope this is the right place for this kinda thread. I'm about to go pick up my newest truck, a 1990 F250, 7.3L diesel, 4x4, auto, reg. cab/long bed that I plan to do some upgrades to and essentially make it as robust as possible.
I plan on doing a few upgrades to it - one being the ZF5 swap. I've already bought a transmission, pedal assembly, no-shifter steering column, et cetera, et cetera. I was wondering if anyone has done anything to upgrade their pedal shaft bushings such as machine their own brass/bronze bushings or even a roller bearing conversion? Has anyone blown a steering column apart and done any upgrades to it? What are some popular upgrades I should look into for an IDI F250? I'm new to the world of diesel trucks.
Here's a short background on me - I'm Matt and I build high end hot rods for a world class hot rod shop in central Texas and oftentimes work with CNC machined parts and machine my own stuff on an upright mill and lathe. So I usually go overkill on stuff but I like pushing the limits of what's possible and elevating stuff where I can. I plan on keeping this truck for a long while so I like knowing these parts are going to last. I might start a build thread just to document everything I've done to my truck so I can share with the community. Is there a sub-forum dedicated to build threads?
Thanks in advance!
Old Yesterday | 06:50 AM
Olds64's Avatar
Olds64
Cool project!
Old Yesterday | 09:03 AM
BigBlue2's Avatar
BigBlue2
I'm not aware of a build forum. You can do it where ever it makes sense. By engine type or by truck years. Haven't had my pedals or steering wheel out to see how bushings are doing. Since yours are out, may as well go over them to see what you can do with them. Look forward to seeing your build thread. If you do it at the Bricknose forum leave a link here so the Bullnose guys can find you.
Old Yesterday | 07:19 PM
tecgod13's Avatar
tecgod13
I did the pedal bushings on my 93 a number of years ago, don't recall exactly when... I put new factory ones in, most likely with a decent grease. Brass or bronze bushing might be an upgrade, not sure if needed. Roller bearing? Way overkill.... And likely useless. The shaft doesn't rotate that far, which may actually be bad for a bearing. Doubt there is enough space in the cast bracket thing to fit one, and why spend the money? I don't recall the plastic ones being that bad when I pulled them out, but I new something was worn out, or just cracked?
If the hole in the housing is egged out, then machine up a bushing to fit. These trucks tend to have issues with the firewall flexing where the clutch master cylinder is mounted. You should look into reinforcing that, I know Ford figured it out at some point, but can't remember if they just made up a bracket and a TSB or redesigned the cab at somepoint. If you are switching from an auto to manual, you cab may not have the reinforcement.
can0fspam
'80-'86 HOWTO's
Sep 27, 2024 07:50 PM
ultraranger
40
Feb 23, 2020 10:56 AM
Bluey Zedoff
113
Jun 2, 2016 08:22 PM
tjc transport
Jan 26, 2016 05:36 PM
lizardman1
Nov 11, 2010 06:53 PM
