Dorothy getting a makeover (i.e.) rhd conversion!
Picture quality is not great. I think I need to brush up on my camera skills, but here are a couple of shots of the old tart in a workshop with the first couple of mods underway.
This picture shows the rhd dash partly fitted. It has yet to have an upper steering column mount fitted to the collapsible Ididit column (part of registration requirements is to have like a two stage collapsible column. One at the shaft and a kind of sliding bracket mount much like modern cars at the top)
I am farming some of this work out, so don't ask me anything technical, but it has a GM (Holden Commodore VT) brake pedal assembly and matching booster fitted. Notice the heavy duty plate mounting it to the firewall. She ain't gonna go anywhere!
This shot shows the multitude of holes that had to be welded up in the firewall. Must have taken hours! Still a couple to do.
Although I have a Jag front end to go in, the builder was recommending I opt for a rhd rack and leave the thing as it is. I am still tossing it up at this stage. Pictured sitting on top of the Heidts Mustang II front end currently in it, is a Subaru unit, (not sure what model) which is very close to the right size, though work would need to be done to fit adapt metric tie rod end shaft to existing. His argument is just keep the current front end in there and save a ton of work, but I have spend a wad on the Jag front with basically new everything, and I have had the wheels machined to suit the hubs etc, and the Subaru unit (for example) is going to require some measure of engineering to fit, probably mitigating any savings I might otherwise make.
I mean, I could re-sell the Jag front end, but my thinking is: it is already complete without any mods needed to the steering rack.
Still have to weld up the dash, fix up some rust and swap the handbrake over to the right and make the steering column bracket. but it is progressing pretty well.
Thanks guys!
Peter
We couldn't find my spring compressors, so I tore down my wife's clothes line. I think an A for ingenuity, but my wife gives me a D for Doghouse
Total chaos! But I think we are getting somewhere! More to come!
Notice how the relocated handbrake lever is now well and truly in the road. A bit hard to tell front on, but there's only about 6 inches space between pedal and tip of handbrake.
Going to have to relocate it left of the steering column
somewhere about here.
More to come...
[/IMG]
Stuart (my welder friend) cutting away the old boxed in section.
Old Mustang II front end cut out. Unboxed rails. Cleaned up ready for Jag IFS
Not quite the perfect fit. But as everyone knows, it needs a notch cut out of the front end to fit
cutting away area to be notched
I am soft mounting it, and this is where the front mounts sit in relation to the chassis. Not sure where to go from here? Fab up mounts off chassis. Anyone have any pictures or suggestions as to what they did here? If anyone has soft mounted theirs before??? Much appreciated.
I'm getting this front end bolted in, not welded. We used high tensile bolts over 3mm plate.
Probably the crappiest bit of the job is drilling the holes under the chassis. Crappy for Stuart. I was sipping beers at that stage
3mm plate with bolt holes drilled.
Stuart was able to avoid cutting out the Chevy engine mounts. Rather handy, that!
Adding a gusset for added strength. Check out those welds! See why I chose Stuart?
More support gussets. Just really nice clean welding, methinks!
Anyway, more to come!
Got me curious now!
I thnk we're doing a bit next weekend. Today I have been told I have to help my mrs paint a room.....boring!
