I used to inspect hazardous materials and explosives that flew on aircraft. When people wanted to argue more than once, I would tell them “Your inability to comprehend doesn’t dictate my accuracy!” I worked with a lot of true type A personalities.
Didn’t get to the plugs yesterday as the truck decided I needed a new battery instead. I did MAPP gas the intake and injectors with zero rpm difference. I know it’s not 100%, but that does narrow down some I think.
A quick search of why ONE cylinder would have a higher EGT than another revealed this:
A single cylinder with a high Exhaust Gas Temperature (EGT) usually indicates an abnormal combustion event where the burn is slow or incomplete, leaving a hot charge to travel into the exhaust pipe. Common culprits include an ignition misfire, a clogged or failing fuel injector, or a leak in the intake or exhaust.
Verify Valve Sealing: A burnt or sticking exhaust valve can allow hot, pressurized combustion gases to escape into the exhaust manifold prematurely, causing a severe and immediate spike in EGT.
I have a dial indicator coming in today so I can measure travel of intake and exhaust. Plan was to do 3 cylinders and compare. Any other ways to verify? Heads were rebuilt about 10k miles ago. I did the water test and made sure no leakage at the time.
The gist is, A/F mixture can cause one cylinder to be different than another. hence looking at the injector in your 'problem' cylinder. Move that injector to another cylinder to ascertain if the problem follows the injector or not.
That cylinder could also be leaner than the rest. I.E. leaking intake gasket causing it to be hotter. If it is lean enough it will take longer to burn or not burn completely in the chamber and will take heat with it on the way out.
I learned this tuning carbs. The eye burning idle that most people think it rich, is actually partially unburned fuel because there was not enough oxygen in the mixture to burn it. So don't just assume it is a leaking injector causing this condition, it could be a partially clogged one too, or a vacuum leak.
Although I held MAPP gas at that area for about 6 minutes with zero idle change, I have not fully ruled out a vacuum leak there. Intake gasket is about 3 years old. I’m hoping for a partial clog injector! Injector itself is about 3 years old as well. I have a bottle of Techron Super in it right now. Whole bottle to about 10 gallons. The tank is about empty. Once I fill back up, I will check temps on primaries again to see if the difference changed enough. If not, I’ll pull upper and swap injectors (move this one to the front so it’s easier to get to). Thanks!
