Adding remote start XLT
Old May 28, 2026 | 05:57 PM
719F250's Avatar
719F250
My 2023 XLT does not have remote start. The app works fine but was wanting remote start via FOB. I have added an additional 4 button FOB with remote start but no starting. What is needed to get the factory option working? perimeter module or what? Thanks in advance and any help is appreciated,
Old May 28, 2026 | 06:11 PM
719F250's Avatar
719F250
Nevermind, Works great after figuring out it is a single quick press and a long second press on the remote. No Forscan or modules after all. Just a $17 remote from the web.
Old May 28, 2026 | 07:09 PM
bobdown's Avatar
bobdown
7th Gear
Could you expand on the module you bought? Does it need to be programmed to work?
Old May 28, 2026 | 08:44 PM
fj5gtx's Avatar
fj5gtx
My XLT has the remote start key fob option. I hit lock, then the remote start button twice.
Old May 28, 2026 | 09:50 PM
The Big Man's Avatar
The Big Man
Trailering
Hmm. Count me in on wanting more information about the fob you purchased. I'm wondering if that will work for my F-150 STX.
Old May 29, 2026 | 07:04 AM
719F250's Avatar
719F250
I didn't buy any modules or altered the programming. Just bought a FOB from Ebay, cut the blade and added to the FOB to the truck using the other two non-remote starting FOBs.
Here is the FOB I purchased.
Old May 29, 2026 | 07:12 AM
bobdown's Avatar
bobdown
7th Gear
Thanks for the info, much appreciated. Apologies for my ignorance - what steps did you take to add the FOB so it would work? I've only done it on Audis where there's a sequence of turning the ignition on (or off, can't remember), lock the door twice with the key, then hold down a button on the FOB until the car beeps. Did you need to do something like that?
Old May 29, 2026 | 08:08 AM
719F250's Avatar
719F250
I first tried the 8 on-off cycle method that most sites have. That didn't work but does give the factory key code. Here is what worked...
Programming Instructions Step by Step:
Use these instructions if your Ford F250-550 has the flip key system.
A maximum of eight keys can be programmed to your vehicle. To program a key yourself, you will need two previously programmed keys (keys that already operate your vehicle's engine) and the new unprogrammed key(s) readily accessible for timely implementation of each step in the procedure.
Please read and understand the entire procedure before you begin.
1. Insert the first previously programmed key into the ignition and turn the ignition from the OFF position to the ON position (maintain ignition in the ON position for at least one second, but no more than 10 seconds).
2. Turn ignition from the ON position back to the OFF position in order to remove the first programmed key from the ignition.
3. After three seconds but within 10 seconds of removing the first previously programmed key, insert the second previously programmed key into the ignition and turn the ignition from the OFF position to the ON position (maintain ignition in the ON position for at least one second but no more than 10 seconds).
4. Turn the ignition from the ON position back to the OFF position in order to remove the second programmed key from the ignition.
5. After three seconds but within 10 seconds of removing the second programmed key, insert the new unprogrammed key (new key/valet key) into the ignition and turn the ignition from the OFF position to the ON position (maintain ignition in the ON position for at least one second, but no more than 10 seconds). This step will program your new key to a programmed key.
6. To program additional new unprogrammed key(s), repeat Steps 1 through5.
If successful, the new programmed key(s) will start the vehicle's engine and operate the remote functions.
Old May 29, 2026 | 08:31 AM
bobdown's Avatar
bobdown
7th Gear
Excellent - thanks very much!
Old May 29, 2026 | 09:25 AM
fj5gtx's Avatar
fj5gtx
Where did you get the blade cut?
Old May 29, 2026 | 10:42 AM
719F250's Avatar
719F250
Local Ford dealer.
BudgetRacing
Sep 12, 2022 12:52 PM
TFin04
Dec 4, 2021 04:11 PM
4wheelfurry
2015 - 2020 F150
Jul 29, 2018 07:47 PM
Remmons
Nov 4, 2015 06:47 PM
