Bolt Size?
Old May 27, 2026 | 06:57 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Bolt Size?
Can anyone tell me the actual bolt size used to secure the radiator to the core support? They are a flange-bolt.
I want to find and order longer ones, because I will be spacing back the radiator itself from the support to create a bit more room up-front for an A/C condenser . Thanks.
Old May 27, 2026 | 08:24 AM
skidoorulz's Avatar
skidoorulz
I believe they are 5/16 24
Old May 27, 2026 | 09:10 AM
TA455HO's Avatar
TA455HO
Lead Gopher
From my 1966 trucks I have these. 3/8" - 16 x 1". 1964 often used a fine pitch thread in places that they changed to coarse thread for 1965-66.
Old May 27, 2026 | 11:21 AM
ibuzzard's Avatar
ibuzzard
Thanks to the both of you for the responses.
Can I tell for sure if they’re 5/16” or 3/8” by the size wrench/socket used on their heads?
Any sources for an exact duplicate bolt, just 1” longer?
Old May 27, 2026 | 11:27 AM
Christmas's Avatar
Christmas
Old May 27, 2026 | 01:29 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I just use my cheapy calipers to measure the thickness of the threads and then a pitch gauge to check the threads per inch count.
The pitch gauge works on nuts and bolts.
Old May 27, 2026 | 01:53 PM
skidoorulz's Avatar
skidoorulz
Most 5/16 bolts take a half inch wrench and 3/8 take a 9/16 wrench.
Old May 27, 2026 | 02:45 PM
ibuzzard's Avatar
ibuzzard
Also, is that bolt type shown in Chad’s photo referred to as a “dog head” flange bolt ?
Old May 27, 2026 | 05:46 PM
skidoorulz's Avatar
skidoorulz
Don't know the real term but I call it a flange head bolt with a star washer
Old May 27, 2026 | 06:26 PM
ibuzzard's Avatar
ibuzzard
Yes, I call them that too, but thought I’d heard them referred to as dog-point. Maybe I dreamt the whole thing.
Old May 27, 2026 | 06:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, dog-point being the unthreaded tip that actually helps get the bolts started and they went to coarse thread to help prevent cross-threading and the speed of installation on the assembly line. Less revolutions to tighten the same length bolt with a coarse thread than a fine thread. They called the washers Lockwasher - external tooth - 3/8" - Once you thread them onto the bolts they pretty much stay put. Sometimes called a Star lock.
Old May 28, 2026 | 09:15 PM
38 coupe's Avatar
38 coupe
My 63 had fine thread bolts holding the radiator in. One of the original clip nuts broke out when removing the original radiator, and I was unable to find replacement fine thread clip nuts. I ordered an assortment of new coarse thread clip nuts. The replacement radiator I bought ended up having the flange at the 6 cylinder location, two inches too far forward. I used 2" thin wall square tube to space the radiator back, and welded brackets onto the 2" tubes for the A/C condenser and the overflow bottle. The whole mess got painted black so it doesn't stand out and look terrible in the engine compartment. I used bolts purchased at the local hardware store.
53fordman1
Sep 19, 2020 04:02 PM
CountryBumkin
25
Jun 21, 2017 10:25 AM
51PanelMan
Nov 15, 2009 04:15 PM
02GrayPowerStroke
Jan 27, 2008 12:45 AM
leonharu
Jan 5, 2007 05:27 PM
