New Radiator Size Problems:
Old Dec 30, 2006 | 04:58 PM
leonharu's Avatar
leonharu
I am trying to replace the radiator in my 1973 F-100 with 360 engine.I went to Advance Auto and they looked it up on the computer and they just happen to have one in stock!I got the radiator and it would not work.It was about three inches to wide ,the mounting bolts would not line up!They orderd one for a 302 engine now.This does not make any since.Has anyone ran into this problem? Thanks,Russell
Old Jan 1, 2007 | 08:29 AM
leonharu's Avatar
leonharu
OK,I think I have figured out part of the problem!There is two different size radiator supports used in 1973-1979.I don't think it matters if truck is a F-100 or 250.I found a radiator that would work,but it is for a 302 and the neck is crooked for some reason? My radiator is 25 3/4 inches from bolt hole to bolt hole on mounting brackett.Radiator part # is D3TA-AHA.I am going to check with Ford and see if they can still order or see if I can get my old one repaired.I know it fits right! Thanks,Russell
Old Jan 3, 2007 | 06:13 PM
Ultramagdan's Avatar
Ultramagdan
Thanks for the update!
Old Jan 5, 2007 | 05:27 PM
madrockwyo's Avatar
madrockwyo
also, some are front-flange and some are rear-flange mount. You can also get a taller radiator, or one with more rows. the options are many
little dutch
26
Dec 27, 2022 05:43 AM
Chris Ko
Jan 16, 2017 11:59 PM
Lance Hogan
Oct 22, 2010 02:53 PM
linckeil
Sep 12, 2009 11:02 PM
dsmm6
Nov 6, 2003 12:50 AM
