I got these parts but the bolt (12-1.75 x 100mm) will not fit the threads in the "upper radiator cushion". The 12mm bolt is too large. A 7/16-4 bolt fits but feels a little loose. BTW, for anyone else reading, the 7/16-14 is the thread size for the front and rear Cab mounts.
Why is the radiator mount a 12mm bolt while the rest of the mounts are US thread? Did you have any issues with the radiator cushion and bolt size?
So my question is, is the 12-1.75 x 100mm bolt correct for the radiator mount?
I'm confused, but that's normal. You got a kit from JBG and the bolt they supplied doesn't screw into the upper cushion. I think I got that part.
But, the bolt isn't really 40-0284 as that's LMC's part number - right? And the cushion is threaded, but not with metric threads. So, why do you have a nut? I would think that having a threaded upper cushion would not require a nut.
Obviously I'm missing something. But, if the JBG-supplied parts won't go together then I'd call JBG.
It looks like the design is that that bolt goes in from the bottom and tightens to the upper cushion. So the Upper and Lower cushions are sandwiched to the frame mount.
Then the spacers and shims that sit on top of the upper cushion along with the radiator support frame and all that is held down with the top nut. Are you suggesting that there should be no threads in the Upper Cushion? (the parts manual 50.1 doesn't have that detail). Also the Upper Bushing has a "hex" built into it so it sits in the frame mount and doesn't spin (I assume so you can tighten it up). Maybe one way to tell is if the Service Manual specifies a separate/different torque for the bolt and the nut.
EDIT: Yes Gary, all the parts came from Jeff's Bronco Graveyard but the bolts "look the same" as in your LMC picture (p/n may be different). The bolt is full-length thread and I confirmed that it is 12mm-1.75 pitch.
This is a picture of the JBG kit - you can see the threads in the Upper Rad Cushion - which is the third bushing over from the left.
Maybe the threads in the Upper Bushing are some sort of "prevailing torque" where the bolt needs to be installed with some force. I was trying to thread by hand - and my 12-1.75mm thread chaser wouldn't thread in either. I didn't want to force anything or cut new threads in it - until I checked with FTE.
However, I may just drill out the threads - I have a three inch body lift, so the supplied bolt is too short anyways. I'm just trying to figure out "what is size thread is correct" so I can look for a longer "full thread" bolt (or drill it out and use a regular 7/14 bolt that is long enough).
I think going 7/16" will work for you since you have the lift. But I'm still confused/concerned about the JBG kit. If there is a nut on top then I don't see why the upper cushion would be a prevailing-torque part. The nut from LMC is, but why the upper cushion?
Sorry - I wan't clear. All the parts came from JBG. The 12mm bolts came with the nuts
Maybe the upper cushion is threaded to keep it together on the frame mount while going down the assembly line - then the Cab and radiator support frame are just set on top. IDK.
You may be right, assuming they are replicating the original parts. And it makes sense that Ford would have the cushions bolted together, which requires the threads on the hat for the upper one, and then someone puts in shims to align the radiator support with the cab so the fenders will line up.
I'm home now, and I was able to run my 12-1.75mm "thread chaser" through the Upper Cushion - so the bolt does fit now. The Upper Cushion part is correct and the bolt is correct.
Now I need to find a 12x180mm fully threaded bolt (if such an animal exists) since I have 3" body lift spacers to get through - or I'll need to drill out the threads as I mentioned before.
My ford one took a M12x1.75x100mm bolt. I did not realize this until after I installed it, but I could have used a shorter bolt, a lot of it stuck out through the top. I bet you could use something a little shorter than a 180mm
I found a couple of places to order bolts on-line. I ordered the "full thread" 12-1.75x180mm bolts. The stainless steel "A2" bolts where cheaper than the 8.8 steel bolts so I got those. I expect that will not be an issue. https://www.accu.co.uk/en/full-threa...Fci4wAodnxsCcw
