propane for freon.
Old May 27, 2026 | 05:27 AM
867.309's Avatar
867.309
Turns out that R12A is sold today: https://redtek.com/12a/
Here's a thread that discusses it some. I didn't read all of it. : https://bobistheoilguy.com/forums/threads/topping-up-with-can-of-r12a-refrigerant.385000/te
That pressure-temperature chart I mentioned earlier will answer questions about operating ranges, to prevent freezing, etc.
For anyone reading this: Beware that this discussion is about using compressed flammable gas in a vehicle air conditioning system. What could possibly go wrong? Am I right? Hold my beer and watch this.
Old May 27, 2026 | 07:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
R-12 has always been available, but you need a license to buy it.
i get it and the R134-A from a company in Florida.
Old May 27, 2026 | 08:27 AM
Hit Man X's Avatar
Hit Man X
Just the EPA 609, it is comically easy to attain. I have about 70lb of R12 here, 1.5 30lb tanks and a ton of small cans.
Old May 27, 2026 | 12:17 PM
tjc transport
i ain't rite
yup, it is. but most people d know know that. heck these days you do the "test" on the internet, with all the correct answers in front of you.
Old May 27, 2026 | 12:20 PM
Hit Man X's Avatar
Hit Man X
I did take it seriously and learned quite a bit!
No tech here, but I can fix most HVAC and MVAC crap of mine easy enough. Even sprung for a high end Fieldpiece gauge set recently that will display wild data and subcool plus superheat
Old May 28, 2026 | 06:57 AM
Talyn's Avatar
Talyn
I can't find a good free version of the spoorlan chart, but thats the basic Hvac tech chart. they make expanded ones.
All these gasses that can go liquid to gas can technically be used in the heat transfer process of HVAC.
So Propane would be usable, its knowing the proper pressures to throw the low/high side in, which I saw mentions of high side adjustments earlier in the thread. Thats something you probably shouldnt' do without expereicne and a set of manafold gauges, but i digress.
Each of your different coolants have different effective ranges of temperature operation, and on top of those effective ranges, it goes deeper into pressure to effective range.
So you can make your 134 vehicle a bit more efficient in the deep south with some changes to the system pressure vs what you'd need/want in lets say... toronto ontario.
This is why most peoples home air conditioning units start working poorly if the temperature gets up around 100-110. The system is optomized based on the pressure to run most efficently at 65-90 most likely.
There is only so large of a gap that can have based on the coolant to pressure. blah blah.
I can't believe I remember all this **** from school 15 years ago. haha
Old May 28, 2026 | 08:16 AM
Rcemaxx's Avatar
Rcemaxx
that’s very useful information. @867.309 gave me a pressure chart for propane/butane but i don’t quite understand how to read it haha.
ambient on left, mixture up top, what are the numbers in the middle? low side? high side? ??
Old May 30, 2026 | 05:41 AM
867.309's Avatar
867.309
Links to a search for: HVAC use for pressure temperature chart. The short story is that is tells you the temperature and pressure where the refrigerant changes between liquid and gas.
https://search.brave.com/search?q=hv...ad9e52e5e1d7a2
cchandler4704
1997 - 2003 F150
Oct 1, 2012 07:29 PM
pauljackmax610
24
May 12, 2010 09:42 AM
chrono4
Iowa Chapter
May 31, 2005 07:59 PM
RawPower
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Oct 24, 2004 07:23 PM
jbalestri
20
Jul 8, 2003 07:58 PM
