Aarons obs seat fix
Old Dec 14, 2014 | 02:23 PM
madMatador78's Avatar
madMatador78
Aarons obs seat fix
Credit for this mod goes to Aaron (fordman67), who pioneered the mod. This can be done casually in a afternoon, if you can find a friend to help that is a plus. We did 2 sets in a afternoon.
Things you will need:
Carpet padding: we bought 6ft of padding from the local Home Depot, it was enough to do 2 sets of seats. You will not need that much for just 1set
6 springs. (3 per seat) They come in a package of 2 that look like this.
<iframe src="https://www.flickr.com/photos/tombombadom/14706711061/player/b32b59d635" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Drill, and small drill bit, used to drill holes for new springs in the frame
Sockets, ratchet, and torx bits to remove the seat from the truck and the seat back.
Sharp scissors, or utility knife to cut the carpet padding
Start by removing the seat from the truck, being careful with the electrical connections and trim pieces.
Take the seat to a work bench and place it face down, if you have something to put down so your fabric doesn't get all dirty, that will help
Remove the trim pieces and hardware that holds the seat back on.
<iframe src="https://www.flickr.com/photos/tombombadom/14709976152/player/64dbff1c02" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
<iframe src="https://www.flickr.com/photos/tombombadom/14523616728/player/5db3d03786" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Remove the 4bolts that hold the track to the bottom of the seat. You may have to move the track to access the other bolts
<iframe src="https://www.flickr.com/photos/tombombadom/14523895319/player/1eb7c09e71" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Next, remove the 4clips that hold the cushion to the seat frame, this will separate the 2. Save the foam inside the cushion as you will be reusing it.
<iframe src="https://www.flickr.com/photos/tombombadom/14523911038/player/427936ef44" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
As you look at the seat frame, study it. Notice that Ford only put springs on the sides and not the center, this causes the seat to sag and lose cushion over time. What we are going to do is drill new holes and add 3 springs, this will help restore cushion to the seat.
<iframe src="https://www.flickr.com/photos/tombombadom/14523903560/player/bc8bedce4d" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
So with your drill,drill 3 holes in the center in line with the existing holes. This is where our new springs will go.
<iframe src="https://www.flickr.com/photos/tombombadom/14729697073/player/f90cbc406a" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Also if you have springs that are about to break through their holes, you can redrill the holes right next to the original holes.
<iframe src="https://www.flickr.com/photos/tombombadom/14707867754/player/9cd68cfc7a" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
With the spring frame in place, use a screw driver or other object so you can set the new springs in place.
Next get your carpet padding and lay the frame down and trace the frame outline on the foam.
<iframe src="https://www.flickr.com/photos/tombombadom/14523597858/player/17bd93501f" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Trim the foam to fit the seat frame. After you get it trimmed, use that piece to make another so you can double layer it.
<iframe src="https://www.flickr.com/photos/tombombadom/14729873493/player/06e08e266f" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
After you get both pieces cut to fit, you can begin reassembly. Lay the foam down on the frame. And then the rest of reassembly is the reverse of removal. It may take more effort to get the cushion back on the frame, but it will fit.
<iframe src="https://www.flickr.com/photos/tombombadom/14523333869/player/6f218a6ab0" height="375" width="500" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Notice how much more flat the seat cushion is.
<iframe src="https://www.flickr.com/photos/tombombadom/14523332929/player/9ff49a5a7a" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
After you put the track and seat back on, put it back in the truck and repeat these steps on the other seats.
And that's how you refurbish you seats.
Last edited by madMatador78; Dec 14, 2014 at 03:12 PM. Reason: added more information
Old Dec 14, 2014 | 02:49 PM
madMatador78
Also, if your spring assembly is broken like mine was, you can repair it. This is what mine looked like and how we fixed it.
<iframe src="https://www.flickr.com/photos/tombombadom/14710267535/player/cf60e97c66" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
<iframe src="https://www.flickr.com/photos/tombombadom/14709972632/player/e5d0667e25" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
<iframe src="https://www.flickr.com/photos/tombombadom/14707871324/player/23df2d2ec7" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Mine was actually broken on both sides. It was in very sorry shape. Aaron said in the 3 other sets that he had done he hasn't seen a spring assembly that was in as bad of shape ads mine was.
<iframe src="https://www.flickr.com/photos/tombombadom/14687015266/player/b935e7fc69" height="500" width="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
If you can I would recommend sourcing one out of a junk yard, but if that isn't an option, this will work as well. It's still holding up after 6months.
Old Dec 14, 2014 | 03:01 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
That's pretty simple. Maybe someone annals it a sticky
Old Dec 14, 2014 | 03:07 PM
madMatador78
Yeah it's not bad at all. Mine just took longer since the springs were in such bad shape. The po actually had my seats switched around, I'm guessing cause the spring was so bad that you would sag to one side.
That would be cool if it was a sticky!
Old Dec 14, 2014 | 04:41 PM
Diesel_Brad's Avatar
Diesel_Brad
Anything to fix the worn out foam?
Old Dec 14, 2014 | 05:58 PM
fordman67's Avatar
fordman67
Actually I add 3 springs.the frames were shorted by the factory IMO.
The foam actually squeezes through.the springs and the new carpet pad do a wonderful job to shore up the middle.obviously the outside corner isn't helped.but doing this helps immensely!!!
I have done HD foam but it is expensive.carpet pad works better and is easy to find and cheap!
Old Dec 14, 2014 | 06:48 PM
Diesel_Brad
I was just curious. I have been repairing these seats for years and now that the foam and covers are obsolete I was looking for a fix. Fixing the springs and adding the backing only goes so far
madMatador78
Fixed it Aaron. So it says 3 springs, 3 holes. I remembered that after the fact. Lol.
Old Dec 14, 2014 | 07:41 PM
fordman67's Avatar
fordman67
No problem buddy.I honestly had to think even after doing SO many sets.
Wish Gabe would let me fix his. I have been daily driving cClifford here for a while and my seats are just delightful. I wonder how Kevin's set is treating him...though I know mistress is not a winter vehicle.
Thanks Thomas for putting that together since I never successfully documented it properly lol
Old Dec 14, 2014 | 07:48 PM
ReBilld's Avatar
ReBilld
Nice write up Thomas! And great job on the seats Aaron!! I have sat in yours, so I know how good they feel!
Old Dec 14, 2014 | 08:36 PM
stainlessstroker95's Avatar
stainlessstroker95
Nice write up. And i sat in aarons too, and they are nice. Aaron i wrote down to have the 3rd off...... Dont know what all you guys have planed though.
Old Dec 14, 2014 | 08:43 PM
fordman67's Avatar
fordman67
Awesome Gabe!
There you go Thomas on the subject from the other night.
Old Dec 16, 2014 | 08:46 AM
Awitte58's Avatar
Awitte58
I recognize dem picherssss.
Great job on the writeup and work guys!
Old Dec 16, 2014 | 08:48 AM
madMatador78
I thought they went with my phone, but they uploaded to the cloud thank goodness.
Old Dec 16, 2014 | 07:44 PM
fordman67's Avatar
fordman67
Cloud? Like where rain comes from?
