As I stare down my Excursion and wonder about iteration 3.0, what would you change on your truck if you could do a 300,000 refresh, besides drivetrain (that's already in the planning stages). I was particularly interested in changing the front suspension over to the newer coil spring setup. Is it better? In what ways? I am interested in a smoother ride and such, and I'm sure my decades-old front b code-modified leafs are weary...what would you do? Thanks for the help!
That sounds great...I'm defeinitely wanting it to turn in/out with ease, my bride hates cranking the wheel on parking lots and such. Looks like you are elbows deep in finding the right solutions. Is there a difference in the 2005 Ex power system for steering or are they the same as the 7.3L?
hope that was not directed at me.,
I have no clue, but my 4x4 does like to turn the wheels on dry pavement.
BUT, I learned 60 years ago, to never try to turn the front wheels,
UNTIL AFTER the vehicle starts to move....
that is something that is hard to teach the newer generations.
Yessir, I was referring to you! You are all-in, and that's the way we collectively discover the best way forward. Thank you, my friend! Yep, we understand momentum makes turning these beasts a lot easier, but some of the parking lot setups these days leave no room on the table. Godspeed!
I've owned both the Ex (on leaf springs) and a 2010 F250 (on the factory coil springs) at the same time, and driven them back-to back, IMHO there is little to no difference in ride quality. Ride quality is more a function of the shocks than the springs (assuming the springs are in the correct spring rate ballpark).
Turning radius is only an issue on the leaf springs with either really large tires (like 37inch plus) or incorrect offset wheels. With 35's and the correct wheels I can go full lock -to lock on the steering without rubbing the springs (of course the larger the OD of the tire, the closer they would get to springs at full lock and there is a point at which they would rub and limit turning radius, so if you're looking to stuff 40's it'd probably be an issue).
Same concept: Hydroboost but different pumps. There is a slight difference in the brake booster between the 6.0 and 7.3 platforms but that's really about it. They even use the same power steering cooler.
Multiple Excursions and Superduty owner here. and I routinely get to drive newer Superdutys at work
-ride isn't that different between leafs and coils. coil is "better". but air pressure alone can change that ride quality.
-turning radius with coils is "better"...but we aren't talking groundbreakingly better. It's just tighter. and you won't scrub 35's on the leaf lol
-steering effort will be nearly identical unless you buy upgraded components.
effort wise, converting to coil springs is barely more effort than replacing the front leaf springs. the hardest part of the endeavor is getting the 20+ year old rivets off the donor truck (hint: buy new 4x4 buckets)
so overall, it's more "what do you want?" for the price of a whole set of new leafs (front/rear), you can buy an entire 2005+ donor truck
I'm looking to get rid of mine, which is 296k miles, shortly after many fun projects, 80k miles over lots of fun trips in 9 years and if I was going to keep mine past 300k I would for sure do the body mounts and rear leaf spring bushings.
Front end and whether the modern SD suspension is worth it really depends on your situation and driving conditions. I have an 05 that is fine on the highway and smooth country roads, but I basically refuse to take it to the mountain dirt roads because it is unbearable. I won't change it, because I have other stuff to drive, but if I ever got into front end work that overlapped with a swap - best believe I'd be doing it.
