Aerostar Ford Aerostar
marooned away from my tools
Old May 18, 2026 | 11:47 AM
ddan's Avatar
ddan
I think my gas got siphoned. Parked out of sight for days. Just put a few gallons in before parking. (No stab wounds in tank, but I left vehicle unlocked.) Cranked it like crazy. Put a gallon in. Gauge deflected. (It didn't before) Fuel rail zert sprays when depressed. Cranks at high speed. Charged battery. Cranks and skips like it wants to start.
Flooded? Timing? Weak pump from running dry?
I don't remember it cranking as fast before. Almost like bad valve timing.
3.0 V6 with 5 speed
Old May 18, 2026 | 02:42 PM
xlt4wd90's Avatar
xlt4wd90
If you were able to crank it for a while, with fuel but no fire, then it's probably flooded. I think the trick to clear that up is to fully open the throttle, then crank again.
But check to see if it's getting spark at the plugs before you go further.
Old May 19, 2026 | 11:26 AM
DFord's Avatar
DFord
Three things needed to start - fuel, spark, compression and a way to turn the engine. If it's getting all three, it will at least backfire if the timing is off.
Old May 20, 2026 | 02:23 PM
ddan's Avatar
ddan
update
Brought my test tools to the van. I thought I'd see if a couple days sitting changed anything. First turn of key it turned over and quit. 2nd turn it cranked a bit then ran a couple seconds with a heavy shake/knock.
The shaking is probably from not firing on all cylinders? There is no knock or shake while cranking.
Old May 20, 2026 | 02:44 PM
ddan's Avatar
ddan
update 2
Tried again after posting previous update. It stayed running, but very rough. Got it to gradually smooth out at higher rpm then it idled better. Not perfect, but could get to be normal at full temperature.
Maybe there was water in the bottom of the tank?
Old May 21, 2026 | 12:09 PM
waterbear's Avatar
waterbear
Check for proper ventilation. If there is a hissing sound when opening the gas cap then there maybe is vacuum build-up in the tank. The relief-valve usualy sitts in the cap, you may try to start and drive the van without cap for a test-drive.
Old May 21, 2026 | 04:24 PM
ddan's Avatar
ddan
venting
The internal filler door is broken and always open. (makes it easier to siphon!) Also the pump/sending unit electrical connector seal is bad (again!) so it is not even liquid-tight, let alone airtight. Have to be careful not to fill all the way or gas seeps through.
Drove it home no problem. Except other drivers!
This thing has 320k on it and the body is shot. Probably going to park it for good next month after the tag expires.
ta2guy73
20
Jul 30, 2014 02:36 PM
FlatHat Ranch
Jan 13, 2014 11:47 AM
pidaster
13
Nov 8, 2009 10:43 PM
fordmanswife
19
Oct 22, 2005 12:57 PM
abelmoreno
Mar 9, 2005 12:52 AM
