Changing the front wheel assembly
Old May 16, 2026 | 10:12 PM
Wgilland59's Avatar
Wgilland59
6th Gear
I was wondering if anyone knew of a way to swap out the front wheel assembly on a 1953 F-350? I’d like to get away from the 6x7.25 wheel pattern and maybe go to discs on the front.
Old May 17, 2026 | 06:08 AM
8pack's Avatar
8pack
Not sure what you are asking not because what you are asking isn't clear, I just am not sure I familiar with the problem you are trying to solve.
Maybe this is what you are looking for? I have this on my 55 F250 and it was a very clean and simple installation. This says for F2 and F3 trucks. 1948-56.
https://www.rusticdiscbrakes.com/pro...disc-brake-kit
Old May 17, 2026 | 06:16 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
The conversation linked here makes it sound like you would need to get an axle assembly from a lower weight class truck.
F350 Disc Brake Conversion
Rustic Disc Brakes
Old May 17, 2026 | 07:25 AM
Bvas's Avatar
Bvas
This link shows the method I and several others have used to convert to 8x6.5 bolt pattern. You do however still run the factory drum brakes.
https://www.ford-trucks.com/forums/1...-raytasch.html
Old May 17, 2026 | 11:18 AM
8pack's Avatar
8pack
Rustic Disc Brakes
I do not believe that is the case with the Rustic Disc Brake kit. It bolts straight up to your existing hubs and spindle.
Old May 17, 2026 | 11:42 AM
Christopher2
Veteran: Navy
I agree, he did say he wanted to get away from the current bolt pattern, looks like you would need a new hub or get his current hubs drilled for a new bolt pattern.
Old May 17, 2026 | 01:56 PM
Wgilland59's Avatar
Wgilland59
6th Gear
This is exactly what I am looking for. Thanks for the link. I hadn’t been aware of these kits.
Old May 17, 2026 | 01:59 PM
52 Merc's Avatar
52 Merc
The 48-52 F1-3 trucks used the same front suspension parts, axle, spindles, steering, etc. Hubs and brakes will interchange, so what fits an F1 will also fit an F2 or 3. The 53-56 trucks were different. F100-250 will interchange, but the F350 is a different beast and everything is larger. F250 8 lug hubs and brakes won't bolt on F350 spindles. The easiest way to go 8 lug on a F350 is to swap out the front axle and spindles with F100/250 parts, and replace the rear axle with a later, up to '72, F250 Dana 60. Then you can utilize the Rustic Brakes F250 disc conversion kit and have all modern brakes.
Old May 17, 2026 | 05:18 PM
Wgilland59's Avatar
Wgilland59
6th Gear
Thanks for the info. There a Dana 70 for sale close by that comes with all 4 rims and tires but it came off of a Winnebago motor home and it had a 5 bolt pattern.
Old May 17, 2026 | 06:24 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
5 on 8 bolt pattern? Could be desirable?
Old May 17, 2026 | 07:02 PM
Wgilland59's Avatar
Wgilland59
6th Gear
it has 5 lug bolts with dual wheels
Old May 17, 2026 | 07:06 PM
bmoran4's Avatar
bmoran4
Those have the potential to be very helpful to someone looking to get away from the RH-5° Widowmakers. Are they 19.5", 20", or 22.5" tires?
Old May 17, 2026 | 07:15 PM
Wgilland59's Avatar
Wgilland59
6th Gear
17 inch tires
KF350
Oct 5, 2021 11:53 AM
Dagwood_55
Mar 5, 2018 07:29 PM
