c6 transmission
Old May 10, 2026 | 10:02 AM
mikey57's Avatar
mikey57
1st Gear
c6 transmission
I have a c6 behind my 351c and watching a video here about replacing servo to an R servo ,do I have to do any internal trans work or can I just pull old one out and put the new one in ? Thanks
Old May 11, 2026 | 09:01 AM
1Butcher's Avatar
1Butcher
An E4OD is not a C6, but they are similar. I am pretty certain you can swap the servo without a complete disassembly.
Old May 11, 2026 | 10:50 AM
DaveMcLain's Avatar
DaveMcLain
I think that the R servo is only compatible with certain levers. Read up on that because I think that if you have the wrong combination it can break the band or cause some weird shift timing problems. Shift timing problems are the #1 killer on a C6.
Old May 14, 2026 | 09:24 AM
PROSTOCK's Avatar
PROSTOCK
I'll have to admit I do not know what an R servo does, but I am curious as to why you think this is necessary? When I rebuilt my the C6 for my '65 I added a Transco shift kit that allows full manual control if you want, otherwise it works normally. It also had 3 levels of shift firmness I believe; I went for the firmest. That might have been a little too aggressive but 30 years later the thing still works great and will bark the tires at both shifts. As far as I know the internals are all original but for the wear items in the rebuild kit....and the shift kit.
elemint
Oct 10, 2004 04:25 PM
ford390gashog
Jun 21, 2004 05:20 PM
duece-bigalo01
Apr 25, 2004 01:38 AM
MKPJ1
Jul 1, 2002 08:07 PM
unioncreek
Nov 11, 2001 11:45 PM
