tranny locked
Old Dec 10, 2003 | 06:14 PM
eveready77's Avatar
eveready77
Angry tranny locked
hey guys, more trouble, here goes...i just swaped a new 360 in my 73 high boy and everything went great the motor runs wonderfully but the transmission seems to be stuck between gears or in a gear. I think it is the np 235? ( 4spd w/granny). This happened when i re-installed the top cover after the swap. Any ideas for realigning the gears, or fixing this stick? Thanks in advance.
Old Dec 10, 2003 | 06:49 PM
79 E350 rescue's Avatar
79 E350 rescue
You may have 2 gears engaged. Pull the cover off and manually slide all the selectors into neutral. You shifter/linkage is probably worn or out af adjustment. It is certainly possible that something is broken too, but you need to pull the cover regardless.
Sean
JHarsh
Apr 24, 2017 03:24 PM
greentruck72
May 12, 2016 10:42 PM
tracyclifton
6.7L Power Stroke Diesel
Aug 10, 2015 11:16 PM
jamusfam
Apr 24, 2014 06:20 PM
kjg26
17
Aug 24, 2006 10:18 PM
