1966 F100 gears
Old 04-23-2017, 04:54 PM
JHarsh's Avatar
JHarsh
JHarsh is offline
1966 F100 gears
I want to swap out stock gears for low end gears. Something that will get me a little quicker off the line. Any suggestions?
Old 04-23-2017, 07:33 PM
john jamieson's Avatar
john jamieson
john jamieson is offline
What's in it now? Ford 9" or dana/spicer rear end? Current gear ratio? The ford 9" is more common and is easier to swap gears.
Old 04-23-2017, 08:04 PM
66v8baby's Avatar
66v8baby
66v8baby is offline
Most likely it's a 9". I would get another 3rd member and get it set up and swap them out when you're ready to reduce down time. If it's the original 9" it's also open, so now would be a good time to upgrade to either a traction lock or a torque sensing rear diff.
Old 04-23-2017, 08:39 PM
JHarsh's Avatar
JHarsh
JHarsh is offline
Its a 9 inch rear with 307 or 310s
Old 04-24-2017, 10:26 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by JHarsh
Its a 9 inch rear with 307 or 310s.
No such 9" ratio's.
Could be: 3.00-1 or 3.25-1.
AXLE code stamped on the Warranty Plate, post what it is.
Old 04-24-2017, 01:54 PM
JHarsh's Avatar
JHarsh
JHarsh is offline
Is this it...
Old 04-24-2017, 03:24 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
Is this it...
Axle code "08" would be for an open (single track) 28-spline differential with 3.50:1 gears.
FordStolz68
04-06-2022 12:54 PM
1963unibody
23
10-22-2015 08:58 PM
Lilryan
03-14-2013 07:52 PM
triton54
Offroad & 4x4
03-31-2007 11:48 PM
shotgun
04-15-2002 08:34 AM
Quick Reply: 1966 F100 gears
