Gear indicator on LCD
Old Aug 9, 2015 | 06:58 PM
tracyclifton's Avatar
tracyclifton
Has anyone else noticed that if you press the + on the gear shift when running in normal drive mode, it toggles a 1-6 vertical gear indicator on the LCD? I found this in the manual and was surprised it can do this. With the gearshift lever in drive (D), press the – button to active PRS. The available and selected gears are indicated on the instrument cluster.
All available gears will display with the current gear indicated. Press the – button again to lock out gears beginning with the highest gear. Example: press the – button twice to lock out 6th and 5th gears. Only the available gears will display and the transmission will automatically shift between the available gears. Press the + button to unlock gears to allow the transmission to shift to higher gears. The transmission will shift automatically within the gear range you select.
Old Aug 9, 2015 | 07:15 PM
kper05's Avatar
kper05
Between locking out gears and using manual mode, it's one of the great features of these trucks. I use manual mode a lot but even in auto mode, I still gear down by locking out gears and add them back as I speed back up, such as leaving a traffic light.
That +/- toggle has been used a lot on my truck.
Old Aug 9, 2015 | 07:24 PM
golfmedik's Avatar
golfmedik
I guess I should RTFM again!!!!
Old Aug 9, 2015 | 08:00 PM
tracyclifton
I read through it when I got the truck. But it seems that I'm always finding something new and trying to figure how how to use it. I have only towed on one trip so far. It pulled so effortless I don't know if I will ever do anything but put in in drive and go.
Old Aug 10, 2015 | 11:06 AM
Painted Horse's Avatar
Painted Horse
That was kinda big news back in September 2010 when we all got th 400/800 flash on our trucks and it added the gear display. But once everybody got their flash done, it become old news.
Old Aug 10, 2015 | 01:19 PM
razehm's Avatar
razehm
I love it and use it when going down hill. Lock out 6th or 5th gear even so it keeps the speed down.
Old Aug 10, 2015 | 11:16 PM
rf4cjock's Avatar
rf4cjock
Don't feel bad. After the PCM reflash on my 2013 F-350 the dealership couldn't figure out where the numbers went. I left figuring the reflash of the PCM did away with the indicators. Found the answer myself and let the dealership know.
Qwazert
Apr 3, 2019 08:32 AM
storage_man
2015 - 2020 F150
Nov 22, 2017 04:06 PM
lkbrow1
6.7L Power Stroke Diesel
Apr 25, 2012 11:19 AM
X-Hibition
Jun 27, 2010 06:29 AM
CheaperJeeper
Feb 15, 2008 10:30 PM
