O2 sensor heater circuit
Old May 4, 2026 | 03:32 PM
  #46
manicmechanic007's Avatar
manicmechanic007
Originally Posted by mackendw
when it warms/dries up here I'll be doing that very test. My brother just dropped off an inspection mirror to check the pipes/valves out.
I had taken the vacuum line off the TAB valve to test to rule out the air from the pump being the source of air being introduced into the mix
causing the lean condition.
Your thermactor system will NOT be causing the lean condition
Old May 4, 2026 | 03:40 PM
  #47
mackendw's Avatar
mackendw
OK. I'm no expert here....just trying to get to the root of the issue.
just ran codes again:
KOEO:
31
KOER:
31
13
77
Old May 4, 2026 | 03:48 PM
  #48
Soup bean's Avatar
Soup bean
It could if there are leaks at the crossover tube to the back of the heads, or the check valve or diverter valve. A leak in one of those would leave the exhaust open to outside air like any other exhaust leak.
Old May 4, 2026 | 03:53 PM
  #49
mackendw's Avatar
mackendw
the cold air heater tube that goes from the air box intake to the exhaust on the drivers side...I wonder if that may be malfunctioning and letting air into the exhaust on that side all the time..... I tested the valve by sucking on the vacuum line that goes to it and it holds vacuum...thinking that was a valid test to prevent the air from going from
the exhaust thru to the air box to warm it up. if air is passing thru to the exhaust from the incoming channel to the air box would that cause a major injection of
air into the exhaust?
Old May 4, 2026 | 04:04 PM
  #50
Soup bean's Avatar
Soup bean
That's a heat exchanger, it's not mixing exhaust with the heated air to the air intake. It's like a furnace in a house.
Old May 4, 2026 | 04:10 PM
  #51
mackendw's Avatar
mackendw
meaning the air incoming thru the air snorkel in the grill, when that valve is opened via vacuum, just allows the cold air to route thru to the exhaust manifold and warm up but NOT enter the exhaust output stream....correct?
Old May 4, 2026 | 08:26 PM
  #52
manicmechanic007
That will shoot exhaust out at the rear of the head not suck air in
That's why there is a 1 way valve on top of that crossover pipe
They leak exhaust like woo wee when that pipe or the one way valve fails
Old May 4, 2026 | 08:52 PM
  #53
mackendw's Avatar
mackendw
if the secondary air pipe/valve that sends air to the CAT breaks and exhaust leaks back towards the engine....that is pushing exhaust out as you say, not sucking air in.
how is the exhaust manifold leaking where it is pushing exhaust out...how is air making its way in in that case?
Old May 4, 2026 | 09:06 PM
  #54
manicmechanic007
It is closer
Old May 5, 2026 | 04:03 AM
  #55
Soup bean's Avatar
Soup bean
Correct.
Old May 5, 2026 | 07:54 AM
  #56
mackendw's Avatar
mackendw
I ran more tests this morning. Checked out the EGR valve (working), EVP sensorV (working) and EVP solenoid - NOT working.... more **** poor quality parts...grrrr....
anyway...I let the truck warm up this time for a longer period...took it out for a 4 KM run...brought it back to the garage and checked the O2 sensor...and lo and behold
it is now switching from .4V - .7V back and forth....so it *IS* working.
now...this doesn't explain the poor mileage....
going to confirm the timing that the guy in Ottawa who I had do the initial work on it.
I marked the current position on the distributor base and the housing so I can return to it.
took spout connector out, fired up truck. if I went any further counterclockwise, truck would not throttle up cleanly.
so I worked it clockwise around 1/8". my timing light was not bright enough to see the markings on the crank pulley.
it is throttling up nicely now. there was a slight delay/lag before when I hit the throttle.
will do a mileage test in a day or so and report the results....thx for all the help/insight...I appreciate it very much!
Old May 9, 2026 | 12:55 PM
  #57
mackendw's Avatar
mackendw
Just re-ran the codes:
KOEO: clear (11)
KOER: 77 ( I'm obviously not doing the brake depress, turn left/right and flooring it at the right time in the test).
all other codes are resolved.
I'm noticing the exhaust whitening out now.
I'm wondering if my pushing air into the exhaust testing for the manifold leak loosened something up.
anyhew...I'll be doing a mileage test shortly and will post the results.
ojh
28
Aug 3, 2016 02:51 PM
dragonwolf204
2004 - 2008 F150
Oct 8, 2015 10:05 AM
740steve
Aug 22, 2013 03:24 PM
jcoleman777
1983 - 2012 Ranger & B-Series
Jun 5, 2013 06:29 AM
mcdiver
Sep 15, 2011 01:24 PM
