7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
2025 6.8 Failure
Old Apr 28, 2026 | 09:40 PM
SMSTX's Avatar
SMSTX
2025 6.8 Failure
We'll be tearing this one down soon. 2025 F250 6.8 with 46k. Came in for a check engine light concern, i guess they couldn't hear the rattle. Misfires on 1 and 5. This is borescope on cylinder 5. Unacceptable photo for prior approval as the VIN has to be included in the picture so the customer will be down for the duration of getting every little shred of evidence they(Ford) can think of. Maybe I'll pull the pan and take a peak at the crank's casting line to see if its forged or cast...
Old Apr 28, 2026 | 11:06 PM
350Recon's Avatar
350Recon
Thanks for the heads up. Will be waiting for the update.
Old Apr 29, 2026 | 06:16 AM
moose927's Avatar
moose927
5th Gear
Suspected lifter failure?
Old Apr 29, 2026 | 06:45 PM
SMSTX's Avatar
SMSTX
Yup, waiting to see if Ford wants us to tear it down or will go ahead and authorize the replacement. The last oil change was 188 miles ago so the filter was clean. I suspect we'll be tearing it down to causal
Old Apr 30, 2026 | 07:20 AM
SMSTX's Avatar
SMSTX
Ford authorized replacement without teardown
Old May 2, 2026 | 10:13 AM
FishOnOne's Avatar
FishOnOne
What a shame...
Been noticing a pattern when a lifter fails and in that associated cylinder also has major cylinder scars. I suspect because there's little compression on that cylinder?
Old May 2, 2026 | 11:32 AM
LEEDSnDeed's Avatar
LEEDSnDeed
How may Idle hours? Carfax oil change intervals?
Old May 2, 2026 | 02:43 PM
SMSTX's Avatar
SMSTX
I'll check idle hours. Oil has been changed almost exclusively at the dealership. As far as the walls getting scored, I think it may be due to the oil squirters spraying the metal off the failing lobe and roller onto the cylinder wall. I won't be able to get any further details til the end of the week as I'll be in a mandatory meeting up north
Old May 2, 2026 | 02:46 PM
SMSTX's Avatar
SMSTX
I took a picture of the maintenance records to submit. Oil was changed approximately every 10k, probably when the OLM tripped. It's a construction company truck
Old May 2, 2026 | 08:08 PM
LEEDSnDeed's Avatar
LEEDSnDeed
Gotcha... The idle time is what I'm really interested in... Idle is hard on the 6.8 and 7.3l. The OLM should be coming on sooner with a lot of idle. So if they are going 10k between LOF's AND they have a ton of idle time, thats a bad combo... Asking for trouble.. My fleet customers OLM alerts come on around 7-8k because they are either working them hard in the F550s or doing a ton of idling like in the forman trucks.
Old May 3, 2026 | 09:25 PM
FishOnOne's Avatar
FishOnOne
If the scoring was from oil squirters than all the cylinders would be scored. Looking forward to what you find out.
Old May 4, 2026 | 08:13 AM
FishOnOne's Avatar
FishOnOne
These trucks better be able to survive idling all day. I know Centerpoint Energy utility trucks idle when on the job site and that can be most of the day.
Old May 4, 2026 | 08:54 AM
saratoga2011's Avatar
saratoga2011
Scoring could be loss of oil pressure caused by broken lifter that creates a "leak" and drop in pressure. Could be caused by incomplete combustion and fuel washing oil off cylinder wall because valves may not fully close or fully open depending on which lifter failed. Etc etc etc etc.
Old May 4, 2026 | 04:57 PM
LEEDSnDeed's Avatar
LEEDSnDeed
Ford may have fixed it by now, but really the only failures seen on the 7.3 when they first came out in 2020 was lifter failures, but only on ones that did a ton of idling. For example an airport shuttle buses. The 7.3l oil pump changed for 2023. Hopefully that was a design change that included a couple extra psi of oil pressure.
FishOnOne. Yep power companies are hard on everything. Idling all day. One of my fleet customers bought 3 Duke energy trucks at Auction that all had about 100k on them.. He thought he got a great deal. He didn't ask me before doing so.. When factoring in idle time they all had more like 350k on all of them. An idle hour meter is prob one of the best features ford added.... .
Old May 13, 2026 | 03:27 PM
SMSTX's Avatar
SMSTX
810 idle hours
