TPMS - NEW TAKE OFFS PROGRAM
Old Apr 23, 2026 | 06:13 AM
bucfan11's Avatar
bucfan11
I am going to install some new take offs on my 25 F350 XL 6.8 GAS. The take offs have the tpms in them. Can I use the Ford built in programming tool or must I use a tool (forscan)
Old Apr 23, 2026 | 06:35 AM
SwanmanV10's Avatar
SwanmanV10
When I switch mine over, they automatically register in the system. No programming necessary. I did the same and bought a set of takeoffs with sensors included. YMMV
Old Apr 23, 2026 | 06:36 AM
VanUno's Avatar
VanUno
I had to use one of these.
Amazon Amazon
Old Apr 23, 2026 | 06:44 AM
bucfan11's Avatar
bucfan11
Originally Posted by VanUno
Thanks, I noticed the latest generation of Super duty is not listed as compatible with this. I assume you own an older generation truck?
Old Apr 23, 2026 | 06:54 AM
VanUno's Avatar
VanUno
I used it on my 2022 F350 when swapping wheels.
Old Apr 23, 2026 | 09:30 AM
6.2caribou's Avatar
6.2caribou
If the takeoffs are from a '23 and newer SD (433MHz), you should only need to mount the wheels on the truck and drive it 5-10 miles. They're programmed sensors that the truck should recognize them with no other input from you.
Old Apr 23, 2026 | 10:00 AM
bucfan11's Avatar
bucfan11
Fantastic! Can't be easier than that. I'll let the thread know if it works.
Old Apr 23, 2026 | 12:20 PM
09FX-4's Avatar
09FX-4
Just mount them and drive them. No tool necessary. Seems to sync faster when you drive 70 MPH.
Old Apr 25, 2026 | 09:19 AM
bucfan11's Avatar
bucfan11
Put the new take offs on, went around the block (less than a mile) to test them, noticed the TPMS system had already picked up the new TPMS. Can not be easier.
Old Apr 25, 2026 | 07:20 PM
wcbcruzer's Avatar
wcbcruzer
Yeah the truck will auto-program after you drive it a bit. For the record, I used that remote on my 2024 and it worked fine. Furthermore, you can let air out of the tires while in programming mode and it'll also work.
hlrndar10
Oct 8, 2024 06:18 AM
Sous
62
May 11, 2024 08:45 PM
Curated Content Editor
General Automotive Discussion
May 16, 2018 09:52 AM
forkliftjoe
25
Nov 3, 2016 04:09 AM
Rusty Axlerod
Dec 30, 2014 08:08 PM
