Semi Smog Delete question
Old Apr 22, 2026 | 07:55 PM
Jad1296's Avatar
Jad1296
7th Gear
I just bought this truck and the previous owner deactivated the smog. He plugged vacuum lines and exhaust lines. The charcoal canister is unhooked as well, but the fuel line is still connected to canister.
Would this cause fuel or vacuum issues?
Old Apr 22, 2026 | 08:49 PM
90project5.0's Avatar
90project5.0
It can push fuel vapors into the engine bay. I would reattach it to the throttle body.
Old Apr 23, 2026 | 08:55 AM
1Butcher's Avatar
1Butcher
Having a working carbon canister/evap system is a good thing.
Old Apr 24, 2026 | 06:48 AM
HydroDog's Avatar
HydroDog
If the carbon canister has been unhooked and left open to allow water to enter, it will now be unusable.
The carbon becomes saturated so now vapor can flow through it and it will need to be replaced.
Old Apr 24, 2026 | 08:31 AM
1Butcher's Avatar
1Butcher
If the carbon canister is left open, I am not certain how water can enter the canister. Sure, there is water in the air, but that will not ruin a the canister. It's the outside air that purges the fuel vapors so it's designed to handle that amount of humidity. If you dunk in in water, I don't know if it will be ruined or not.
Old Apr 24, 2026 | 11:53 AM
HydroDog's Avatar
HydroDog
If the PO unhooked it and for whatever reason has taken a hose to wash the engine compartment, water could have entered it.
I’ve been down that road before troubleshooting before.
Old Apr 24, 2026 | 12:49 PM
Scndsin's Avatar
Scndsin
Charcoal does not go bad from being wet, it doesn't disolve.
Billions of water filters from giant to small are in existence world over.
Pour water out of canister (if there is any), set in sun for a day or two., reinstall.
jgavac
Dec 25, 2011 03:23 PM
Hagerhorrible
May 24, 2011 07:29 AM
southern hunter56
Feb 13, 2011 08:29 AM
johnmvtv
Apr 4, 2007 04:48 PM
