1978 - 1996 Big Bronco
rear window defroster
Old Dec 10, 2003 | 04:22 PM
killerklown's Avatar
killerklown
What is the best procedure for re-attaching the rear window defrost contacts to the window. They have both popped off the glass.
Old Dec 11, 2003 | 08:49 AM
BillyBob69's Avatar
BillyBob69
Check with your local window tinting shop. They should have the adhesives to use. I have used superglue, but specialty adhesive is better.
Old Dec 12, 2003 | 06:48 PM
89BroncoResto's Avatar
89BroncoResto
I'm an electronics guy, so I soldered mine back on about 3 weeks ago. If you do that, make sure the glass is warm, and use a low temp soldering iron. Good luck.
bironacad
Mar 15, 2014 06:02 PM
fordtrucknut
37
Feb 5, 2009 04:19 PM
3headedboris
Mar 31, 2004 03:28 PM
Mr Baja
Jan 15, 2002 09:24 AM
sticky
Mar 21, 2001 12:09 PM
