Clunk in drivetrain
Old Apr 19, 2026 | 01:11 PM
Lex2002's Avatar
Lex2002
Clunk in drivetrain
This has been going on for a few thousand miles and I need to address it. I get a hard clunk or jolt in the drivetrain when I let of the accelerator at highway speed.
I also feel in the 1-2 shifts
My guess is a broken motor mount letting the engine and trans shift but it seems our motor mounts are bulletproof.
What else should I be looking for? Drive shaft u joints? (I've changed them at least once in 230k miles).
Y'all rock!
Old Apr 19, 2026 | 01:16 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Could also be excessive backlash in the ring and pinion.
Old Apr 19, 2026 | 01:51 PM
Socket's Avatar
Socket
Check your carrier bearing if it’s a two piece rear driveline
Old Apr 19, 2026 | 02:21 PM
Barkyy's Avatar
Barkyy
Exactly what i was gonna suggest to the OP
Old Apr 19, 2026 | 02:59 PM
Lex2002's Avatar
Lex2002
ok will check the carrier bearing and pinion. Both of those have less than 40k miles so I ruled then out in my head.
I had to change the entire rear axle years back and the carrier was changed with the transmission.
Will report back.
Old Apr 19, 2026 | 06:01 PM
Lex2002's Avatar
Lex2002
One thing I forgot to mention is that also does that jolt when I come to a stop. Unless its a very very slow, creeping stop.
Checked my notes and the carrier bearing has 40k miles on it as does the replacement rear axle.
Carrier bearing rubber looks ok. Slight bleeding from rear of the bearing.
I put the truck in neutral and used a 3 foot pry bar...really couldn't get much movement out of the shaft at the pumpkin for whatever that's worth.
The 3 driveshaft u-joints MAY be original! GULP. Will take care of all 3 in May.
Perhaps one is sticking and forcing the carrier bearing to shift around?
Old Apr 19, 2026 | 08:13 PM
Lex2002's Avatar
Lex2002
What about slip bump from the slip joint? Like in this f150
Old Apr 20, 2026 | 08:55 AM
Texmax's Avatar
Texmax
Very crusty underneath. Are you in the "rust belt"?
Man, they know how to ruin vehicles up north and keep the manufacturers in business.
Old Apr 20, 2026 | 10:40 AM
FordTruckNoob's Avatar
FordTruckNoob
Check to see if the pinion nut has come loose. Common issue.
Was the replacement axle fully rebuilt before installation?
Old Apr 21, 2026 | 07:58 AM
Lex2002's Avatar
Lex2002
Will check it when I drop the drive shafts to change the u joints! Thanks for the idea!
Yes it was a fully rebuilt rear axle with new parking shoes on it.
To me it feels like the engine is is shifting around...but hey...I'm dumb as a brick.
Old Apr 21, 2026 | 08:26 AM
Lex2002's Avatar
Lex2002
Maryland.. so no not really the rust belt. Doesnt snow much here.
aroesti
Feb 2, 2023 01:44 AM
e30rik
18
Aug 18, 2021 11:49 AM
68Flareside240
Jun 17, 2020 10:20 PM
cworley250sd
Oct 9, 2007 07:48 AM
OzFTrucker
Mar 21, 2006 10:25 AM
