Clicking noise from dash
Old Apr 17, 2026 | 03:00 PM
Thechap1's Avatar
Thechap1
4wd Low
I have a 2014 Ford F150 XLT which developed a weird clicking noise yesterday. When you open the doors, any door there is a loud clicking noise coming from the drivers side dash. I attached a short video for you to hear. Any ideas what it is?
File Type: mov
Old Apr 17, 2026 | 03:06 PM
Thechap1's Avatar
Thechap1
4wd Low
Hoping this video works.
File Type: mov
Last edited by Thechap1; Apr 17, 2026 at 03:08 PM. Reason: Trouble with video. Please delete.
Old Apr 17, 2026 | 05:23 PM
rbentnail's Avatar
rbentnail
Sounds like you might have a stuck blend door skipping teeth. Do all your heat, cool and air flow directional (dash, floor, defrost) work properly? Last time for me I had no heat, cool/cold only.
Old Apr 18, 2026 | 11:32 AM
Thechap1's Avatar
Thechap1
4wd Low
It's on weather the heat/air conditioner is on or off. It's definatly coming from under the dash on the driver side.
Old Apr 20, 2026 | 09:46 AM
HomerWinzlow's Avatar
HomerWinzlow
If it sounds more behind the cluster than the radio then its likely the mode door actuator. Crawl under the driver side and turn the key to on and listen for the pop sound. Put your hand on the device that is popping. Will likely be the actuator on the driver side of the plenum. Unplug the connector to it and see if the noise no longer is made. If so replace that actuator. If it sounds more like it is coming from behind the radio then it is the temperature blend door actuator.
EXv10
Aug 15, 2013 05:41 PM
Redleg105
Feb 2, 2013 03:17 AM
richardmiller
Feb 7, 2012 05:22 PM
S.uper-My-D.uty
Jan 26, 2012 04:31 PM
6litrefan
Aug 23, 2010 08:07 PM
