Generator vs Alternator
Old May 7, 2026 | 08:22 AM
  #31
tico47's Avatar
tico47
Originally Posted by bmoran4
A few technical questions...
What is the theory of operation?
Does it simply drive the generator at a constant and then raise/lower the BAT terminal voltage?
What is the frequency range and/or shape of the Field terminal signal?
What are the capacitance limits (ie for Radio noise suppression etc) on the Arm terminal?
What is the current limit? Is it adaptable to the different Ford/Mercury generator options (I see no configuration components such as jumpers or dip switches)?
I will pass this info on to the person that developed this regulator. He can answer these questions better than me and I will get back to you with the answers
Old May 7, 2026 | 08:25 AM
  #32
tico47's Avatar
tico47
Originally Posted by 8pack
Let us know when they might be available for sale!
I will check with him on what he feels the price would be. You would have to supply the core for him to retro fit everything
Old May 7, 2026 | 08:54 AM
  #33
hooler1's Avatar
hooler1
What is the current limit? Is it adaptable to the different Ford/Mercury generator options (I see no configuration components such as jumps or dip switches)?
I have had simuilar thoughts. I was wondering how the unit handles the function of the mechanical cut out relay. The cut out relay is basically the "referee" of the wrestling match between the battery and the generator. Who ever has the highest voltage at the time is the winner. But that can change 100's of time in just seconds, thus the fuzzing arcing you see between the cut out relay contacts.
Temperature compensation was another thing I was wondering about. That is a normal mechanical regulator, like an old style mechanical thermostat, has bi-metal in its armatures to compensate for charging the battery at higher under the hood temperatures. And finally can it handle a sustained 30 amps of current if a battery is severly discharged?
I am sure the desinger is a brilliant person, and it looks like a work of art! It's going to be interesting to see how it all works out in the long run.
Old May 16, 2026 | 11:34 AM
  #34
lshort's Avatar
lshort
No question, Alternators are better than a generator but if we wanted the latest technology we would not be driving 75+ year old trucks in the first place
Old May 16, 2026 | 01:04 PM
  #35
tico47's Avatar
tico47
This is true
Old May 17, 2026 | 09:23 AM
  #36
Brian1950F4's Avatar
Brian1950F4
I enjoy driving mine. Alternators have made that possible.
Old May 17, 2026 | 04:26 PM
  #37
tico47's Avatar
tico47
It wasn't the generator that I was having the problem with, it was the regulator. At one point I was thinking about changing over to a 6 volt pos ground alternator. The more I thought about it I decided not to as I am trying to keep it as original as I can. You can get a better re-sale for it if it is original. The last thing that I have to do is change out the oil pressure gauge. I am not looking forward to getting under the dash to pull out the instrument cluster. I am far from being as young as I used to be .
Old May 17, 2026 | 09:21 PM
  #38
Brian1950F4
Adding the alternator eliminates the voltage regulator problem. And I stayed 6v, pos ground. As to getting under the dash, that gets more difficult every year it seems like. If you can take your seat out it givesyou more room to work.
Old May 17, 2026 | 09:29 PM
  #39
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Use of an alternator does not eliminate a voltage regulator (and their point of failure). Some alternator systems use external regulators similar to our generator setups. Other alternator systems/styles move the regulator inside the alternator housing.
Old May 17, 2026 | 09:34 PM
  #40
Brian1950F4
It internalizes it. No wiring issue, no figuring out which wires to jump together. Much easier. I know you don't like them. But I switched to alternator on 3 of my vehicles and they are much more enjoyable to drive and a lot less dependability issues.
Old May 17, 2026 | 09:50 PM
  #41
bmoran4's Avatar
bmoran4
I don’t dislike alternators - I myself own vehicles and equipment that use them. What frustrates me is when people take pride in avoiding systems of which they are not familiar, such as these generator/regulator systems, instead of learning how to work with them. It reminds me of the absurdity seen in some of the younger people who are unable to and see no reason to learn how to read analog clocks simply because digital clocks exist.
Old May 18, 2026 | 07:40 AM
  #42
tico47's Avatar
tico47
How does the 6 volt pos ground alternator wire up??
Old May 18, 2026 | 09:43 AM
  #43
bmoran4's Avatar
bmoran4
It depends upon the specific alternator setup. Some setups have sense wires (controls the internal voltage regulator - this goes close to the load center/fuse box, distribution point, battery sense wires go right to the battery)), idiot light signals (illuminates in discharge situations - this goes to the indicator), and bootstrap inputs (alternators are not self sufficient - they need bootstrap current to energize the charging system). Some setups take shortcuts and internalize these things to market themselves as "easier to wire", but then they don't separately sense power demands, charging demands, battery state and so on and so on. Other setups have external regulators and accompanying wiring.
Old May 18, 2026 | 10:03 AM
  #44
hooler1's Avatar
hooler1
If you are looking at doing this swap it looks like now is a good time to buy one. I see Speedway has them on sale right now.
https://www.speedwaymotors.com/Powermaster-PowerGEN-1949-53-Flathead-Ford-1-Wire-Alternators-6-Volt,42290.html
Old May 18, 2026 | 05:33 PM
  #45
pintoplumber's Avatar
pintoplumber
We were talking to a school teacher recently who said they took all their clocks out and put digital ones in.
