I sure hope someone can help me. My information display screen is malfunctioning. The voice commands work fine, so that I can get get most things done through voice. But the clock display is what shows up and if I try and push any button on the display, it moves to the map display. .Very few of the buttons on the display operate as they should.. The only real practical problem that I have is that I cannot turn on the air conditioned seats.
I have pulled off a battery cable on each of the two batteries in the hope that after 15 minutes, it might reset. I also turned the ignition on (but not the engine) and held the gas and brake pedal down for 15 seconds and then tried to see if that would do a reset . On the screen there is a 'display' button and 'Settings' buttons, but as I said, these don't work.
I don't know what next steps are.. If this is a $2000 repair, I don't know if I need my air conditioned seats that badly.
Please help if you can Thank you
Doesn't your dash have buttons for the seats? My 350 does. Red for heated, blue for cooled. Including more information about the trim level of your truck will help.
