EVAP purge valve ?
EVAP purge valve ?
Where is the EVAP purge valve on a 2001, 5.4L 2 valve..... engine diagram if someone can post an image. Passenger side I'm assuming the thing that sounds like a mad Bee !
I think this system has been deleted on this, as the hose to cannister on driver side is missing or fell off ?
It's been awhile since I had a 5.4 but I think they are all pretty similar. I had a van with a 5.4 and the purge vale was located on the firewall near the brake system.
I googled it and there are a ton of photos of it in that location. But a few photos showed it located under/near the throttle body intake. The parts look identical but in different locations.
This thread states their 01 5.4 evap purge valve was indeed on the firewall. https://www.ford-trucks.com/forums/1...150-5-4-a.html
Two vacuum hoses and an electrical connector.
Hope this helps. Or maybe someone with some fresher info can chime in.
