Sponsored by: Real Truck
PCV questions
Old Feb 12, 2023 | 09:55 AM
WI-ID's Avatar
WI-ID
2nd Gear
PCV questions
I'm looking for the location of the PCV valve on a 2008 F250 V10. Also there seems to be a control valve connected to the crankcase hose on the drivers valve cover. (maybe this is the pcv valve) The valve is located on the rear of the engine and has 2 coolant lines attached to it. Does any one have a name for this valve. Can't come up with any listing for this valve on the ford parts site.
Thanks
Bill
Old Feb 14, 2023 | 08:49 AM
53burb's Avatar
53burb
I dont know for sure on your 2008, but on 2005 V10s, there is no easily replaceable PCV valve. From what I have read, the PCV valve is located IN the drivers side valve cover and is NOT replaceable. The valve cover can be removed and spray some carb cleaner or other solvent in there, but I guess thats about it....or remove the hose from the VC and spray in there. 2008 is probably the same....
WI-ID
Modular V10 (6.8l)
Sep 4, 2023 05:07 PM
Chopper_WSP
Modular V10 (6.8l)
Jul 19, 2008 11:24 AM
b4000 owner
1983 - 2012 Ranger & B-Series
Mar 6, 2005 08:54 PM
jkgulledge
Oct 29, 2002 05:08 PM
