Ignition Upgrade
Old Apr 12, 2026 | 09:51 AM
Country Bumpkin's Avatar
Country Bumpkin
Ignition Upgrade
Spring is threatening to arrive, and I'll be getting my '72 390 (currently on Engine Stand) ready to be dropped into my '72 F350.
NEXT Winter - I'm going to have the time and $ to do a complete rebuild on it, including an RV cam, 4 Barrel w/Performer Intake, and Pertronix Upgrade.
It's a good running 390 now (approx. 65K miles), and I'm just wanting to get it in, and get my Truck going.
So, I'm just doing an Oil/Filter Change (VR-1 & Wix), New Holley 500 CFM 2 Barrel, Headers, and Plugs, Wires, Distributor Cap & Rotor.
Regarding that, I was wanting input on the choices I've made (below).
Thanks for any Input.
https://www.summitracing.com/parts/sum-888901
https://www.summitracing.com/parts/msd-5506
Old Apr 13, 2026 | 07:52 AM
manicmechanic007's Avatar
manicmechanic007
Opinions are like A holes, everybody has one
But
I'd rather see you use a factory Duraspark II distributor from a 75-76 truck with a 360
What you have planned for the 72 390 motor sounds good
Consider forged pistons for longevity and I'd go 10 to 1 flat top
That motor will handle 12.5 to 1 if you want to find fuel for it
I have access to Sunoco 130 leaded around here
Old Apr 14, 2026 | 04:57 PM
GrandStang's Avatar
GrandStang
Do you have your old carb and/or exhaust manifolds? I only ask, because if it were me, I'd rather save the money from having to buy 2 carbs and manifolds/headers (one now and another later) and instead use that money for the Petronix upgrade.
Just my 2 cents.
Old Apr 15, 2026 | 05:44 AM
Country Bumpkin
I already have an Edelbrock Performer Manifold, and a set of Headers.
There's a reason (complicated) why I'm doing some things NOW and some things later.
But, if there were ONE thing that I may do up front (NOW) it's possibly the Pertronix up grade.
I'm (right now) in the process of watching videos, etc., of the Pertronix install, and getting educated on it.
I also need to decide whether I want the Ignitor 1, 2, or 3.
Thanks,
Old Apr 15, 2026 | 09:45 AM
GrandStang's Avatar
GrandStang
For what it's worth, I went with the Ignitor 1 on my bumpside. It's got a bone stock 302-2v, so for $100 the Ignitor 1 seemed like the obvious choice for me.
Old Apr 15, 2026 | 04:34 PM
Country Bumpkin
Thanks. I'm looking at all of them currently.
Did you have to change your Coil when you upgraded your Distributor?
I've seen numerous videos of Installations - some change the Coil, and say it's necessary. Others don't.
I don't get it.
Old Apr 15, 2026 | 05:13 PM
GrandStang's Avatar
GrandStang
I didn't. It depends on whether or not your rig has a ballast resistor. The ignition system had been chopped up on mine, so I didn't have to worry about it. Just make sure your coil is putting out 12v to the Ignitor.
Old Apr 15, 2026 | 07:08 PM
Country Bumpkin
Thanks.
Yeah - 12 VDC to the Coil.
So.......I may not need to purchase a new Coil.......Winning!
My other question was about Plug Wires - I'm getting some good ones from Summit.
They should be okay, right?.......
Old Apr 15, 2026 | 07:35 PM
Country Bumpkin
These are the "Special" Pertronix Flame Thrower Plug Wires - 500 Ohms:
https://www.summitracing.com/parts/pnx-708104/make/ford
These are the "Standard" Plug Wires - 50 Ohms:
I'm wondering......If I don't do the Pertronix upgrade right away (I'm leaning towards), can I go ahead and get the Pertronix wires - will they work fine?
Or.......should I get the Standard wires, and then use them with the Pertronix if I choose to convert?
(If I was a Millionaire this would not be an issue).
Old Apr 16, 2026 | 01:31 PM
Mikulh's Avatar
Mikulh
Recently my Pertronix died (it served me well for 20 years) and I put my points and condenser back in my distributor. I installed my old coil in place of the Pertronix coil.
However, I didn't change my Pertronix spark plug wires (I didn't realize they were different) and everything seems to be running and performing fine with the Pertronix wires and the points and condenser.
ZebH
Oct 6, 2018 02:53 PM
earnie
Sep 12, 2009 06:27 PM
jaydgraff
15
Jun 23, 2005 11:17 PM
FalconStng
Mar 13, 2005 04:00 PM
samckernan
Dec 31, 2003 09:47 AM
