Noisy 302
Old Apr 7, 2026 | 04:10 PM
Sycostang67's Avatar
Sycostang67
Noisy 302
The guys and I are back to tinkering with this 302 again. 1993 F150, swapped in a supposedly good salvage yard 302. Bearings and cylinders looked good, you could tell it had probably missed and oil change or two due to some baked on oil but nothing like the charcoal briquette of a block we replaced. Installed new comp cam, seals, gaskets and oil pump. There was a rattling noise coming from what sounded like the passenger side valve train. Installed new ford performance lifters, sound moved to the other side. Oil pressure is only at the “O” in normal on the gauge. Pulled intake again to verify oil flow through lifters and push rods. Oil is a little slow to reach the first rocker on the passenger side but does get there. Buddy wants to install a high pressure oil pump to see if that helps, his truck his call but thought I would see if anyone has other ideas. I was wondering if the rockers could be worn out. Mileage on this motor is unknown but it was sold with a warranty and lead slugs so I assume it was tested before it was sold. That was probably 10 years ago though.
Old Apr 7, 2026 | 05:15 PM
90project5.0's Avatar
90project5.0
I would check actual oil pressure with a gauge first to see what real readings are. I can twist the wire on my sender and it change the readings. Once I realized that, I added an electric oil
pressure gauge.
Old Apr 7, 2026 | 05:55 PM
Prototypemech's Avatar
Prototypemech
Anyone with a 9th Gen ford truck will tell you that the Oil pressure gauge is just a dummy gauge. Anything over 9 PSI will cause the gauge to move to the middle position. Anything less than 9 PSI will move the gauge to the RED position. Anyone who claims their oil pressure gauge is fluctuating usually has a dirty oil pressure switch or a loose electrical connection.
You need to install a real mechanical or electrical oil pressure gauge on it if you want a real reading.
Old Apr 7, 2026 | 05:59 PM
90project5.0
My cluster gauge hangs around between o and r usually. My actual gauge reads around 35 idle and 60 driving when fully warm.
Old Apr 7, 2026 | 06:40 PM
Sycostang67
We put a mechanical gauge on it last year to check and I can’t for the life of me remember what the reading was. I can’t imagine it was bad but I will toss it on again to double check.
Old Apr 7, 2026 | 07:17 PM
90project5.0
If it moved to driver side after replacing lifters, check for play between rockers and pushrods. Maybe one of the lifters isn’t fully pumping or just a tolerance problem with non adjustable rockers. With my pressures, I have a slight tick on passenger side. I have roller rockers, but I can tell middle of passenger cover that’s where it’s coming from. New heads by the end of the year will solve my problem since ill be changing to adjustable rockers.
Old Apr 7, 2026 | 08:22 PM
Prototypemech
8th gen trucks had real oil pressure gauges.
Old Apr 8, 2026 | 04:25 AM
manicmechanic007's Avatar
manicmechanic007
Good idea
A few things
5 psi will illuminate the idiot light
There was a TSB to add a resistor to the circuit to make the gauge read higher but that did nothing for low oil pressure
If your engine is noisy, check the "direct or actual' pressure at hot idle
Old Apr 8, 2026 | 05:54 AM
90project5.0
My 90 has the “normal” sweep.
Old Apr 8, 2026 | 11:08 AM
Junktownbill99's Avatar
Junktownbill99
The bricknose trucks had a real gauge? I thought they stopped after the bullnose?
Old Apr 8, 2026 | 11:39 AM
90project5.0
mine didn’t
Old Apr 8, 2026 | 01:51 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Some do. Some don’t. The ‘87 Bronco had a real gauge while the ‘89 F-150 did not. I don’t know when in ‘88 that changed.
Old Apr 8, 2026 | 10:12 PM
Prototypemech
I learned something new.
Old Apr 11, 2026 | 02:43 PM
Sycostang67
Cold start, oil pressure is just over 50psi. Cant get it warm yet as we have no coolant in it. Currently replacing a mangled header to reduce some of the noise we are hearing.
Old Apr 11, 2026 | 05:13 PM
Sycostang67
Pulled a valve cover and all the rocker arms are loose. They are torqued to spec, cam is compatible with stock push rods.
