Unfortunately I don’t have a tool for that. We just found the closest size to stock and went with it. I just don’t understand how a cam that should work with stock pushrods and lifters that should work with stock pushrods don’t. I figured if the pushrods were too long we could shim the rockers?
I will add for a roller cam motor! I know, assumptions..
I removed the flat tappet in my ‘89 and installed a roller cam with GT40 heads and Scorpion rocker arms. The pushrod checker tool came up with stock length roller cam pushrods.
The new pushrods were too long which I thought they would be but it was taking 4-5 shims to even them out. Right now we are thinking about a rocker stud conversion kit and running some adjustable roller rockers. I even tried a new rocker arm just in case the old ones were really worn out but no luck.
Another thing I have been pondering is just getting some screw in studs and using older style adjustable rockers like the ones on the 1969 351w in my old mustang. They are adjustable and don’t require guide plates as the valve side of the rocker has lips that keep it centered over the tip of the valve stem.
I have also contacted summit about the cam and they have no answer as to why the stock pushrods won’t work.
This is a bit of an odd one. The Comp CCA-35-512-8 should use a 6.248" stock length pushrod in a factory roller 302. Adding lift does take away from the base circle, but this isn't a "big" cam, and Comp calls it out as working with stock pushrods, so that alone shouldn't make the pushrods seem drastically too short.
Something else in the valvetrain stack is likely causing the discrepancy in pushrod length.
Lifter seat height
Collapsed or fast-bleed lifters
Valve tip height
Pedestal/rocker stack differences
That said, if those are Ford Performance FMS-M-6500-R302 lifters, they are intended as stock replacement hydraulic roller lifters, so we normally wouldn't expect a major seat height difference there.
Either way, you still want good geometry. Even with adjustable rockers, you’d still want to verify preload, rocker sweep pattern, etc. For those Ford Performance lifters, Ford recommends around .020"-.060" preload, or roughly 1/4 to 3/4 turn past zero lash.
