Fuel Filter
Old Mar 30, 2026 | 08:00 AM
Doubleclutch's Avatar
Doubleclutch
Yes I have the plastic fuel filter there and then I have the factory screw in filter at the carb.
It was just the way my truck came to me as so I kept it that way as it cant hurt anything.
I am pretty sure the plastic or metal filters the links show are less money than the one you have.
Dave ----
Yes it is more expensive, but I read some reviews on the cheaper one from AutoZone or O'Reilly's and they said looking through it all you can see is a screen that doesn't appear very fine. Like smaller particles could go through it. The Purolator has a much better filtering system. I don't know if all that's true, but for a few bucks more I'll be happy in my delusion that I bought a better filter. 😁
Old Mar 30, 2026 | 08:10 AM
FuzzFace2's Avatar
FuzzFace2
I wonder if you were looking at the glass type filter that you can remove the screen filter to clean or replace?
If so run away for that type, glass filter, as the glass can break and gas then sprays all over the hot motor and starting a fire.
The plastic ones I am and think the other are, use the same filtering stuff inside as the metal ones, no screen, but with the plastic you can see if there is fuel in it and if you start seeing it have dark part at the bottom you know you got a problem.
Then metal filters you cant see that. The 77 Jeep DJ I just got uses a plastic fuel filter and feeding it off a gallon can so we could see when the pump started pulling fuel. It has been sitting for a year and the old gas needs to be dumped and tank checked before I can use it.
Dave ----
Old Mar 30, 2026 | 08:22 AM
Doubleclutch
Dave ----
Good point, maybe I'll get the plastic one and return the Purolator to amazon.
Old Mar 30, 2026 | 08:49 AM
FuzzFace2's Avatar
FuzzFace2
If you have the metal use it for a year or 2 and then change it for the plastic type.
Or get the plastic one and hole on to that metal one. There is nothing wrong with it and I have used the metal ones but if you are working out a fuel issue it is nice to see if the filter has as in it.
Dave ----
Rich1961
2023+ Super Duty
Nov 26, 2025 11:09 AM
Fmc128
2023+ Super Duty
Mar 13, 2025 08:25 PM
Qwazert
6.2L V8
Oct 26, 2024 09:17 PM
61 uni
Nov 22, 2008 08:20 AM
