Gear Ratio Suggestions
Old Mar 22, 2026 | 04:49 PM
Joshf100's Avatar
Joshf100
Hello everyone, i currently have a 73’ f100 paired with a 390fe and a NP435 on 3.25 open differential. I am wondering if it’s a smart option to bump it up to a helicol 3.50 ratio? Currently I have 265/65/16 wheels on the truck and it does 80mph at around 3,000rpms on the highway but I do feel the acceleration is quite slow to get up to higher speeds at 4th gear anything after 2.8k rpms. If anyone had any suggestions on what you guys run or what you guys would recommend thank you all for reading.
Old Mar 22, 2026 | 05:07 PM
Rubiranch's Avatar
Rubiranch
What are you looking for or what is the primary use of your truck?
Traveling, power, towing???
I think 3.73 are ideal gears for a truck.
With you 29.5" tall tires,
3.73 gears
80 mph 3400 rpm
65 mph 2750 rpm
45 mph 1900 rpm
4.10 gears
80 mph 3700 rpm
65 mph 3000 rpm
45 mph 2100 rpm
Old Mar 22, 2026 | 05:32 PM
Joshf100's Avatar
Joshf100
I use the truck for occasional uses like 4-5 times a month but no hauling, the truck is mainly on the highway but I would like to feel some power throughout the gears from time to time. I’ve read some people stick with the 3.25 gears because the highway friendly rpms but like I said I really don’t feel much of a punch when in street use although I understand I can’t have both low rpms at highway and very punchy off the line.
Old Mar 22, 2026 | 05:48 PM
Rubiranch's Avatar
Rubiranch
Then maybe try 3.0 gear.
Old Mar 22, 2026 | 05:54 PM
tbear853's Avatar
tbear853
I think mine hit 80 once in the 1980s. It was a long pass, knocked down a couple TTs and a white PU pulling a camper on one of the few passing zones of that road ... in Georgia.
3.50 gear, Auto, 31" tires, 2,450 rpm = ~60 mph.
Old Mar 22, 2026 | 09:10 PM
Rubiranch's Avatar
Rubiranch
75 mph, 32" tires 4.10 gears - 3200 rpm.
3450 rpm at 80 mph. And sucking gas like there's no tomorrow.
Old Mar 22, 2026 | 11:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
What size tires you run?
Old Mar 23, 2026 | 10:49 PM
motorsickle1130's Avatar
motorsickle1130
If it’s mostly hwy, sounds like an overdrive should be in your future.
Im running 3.54:1 on 32.5” tires with 1:1 final, and turn 2200 rpm at 60, 2550 at 70, and just shy of 3k at 80. Plenty of scoot with a rebuilt big block and 4spd.
Try playing with your numbers here: Novak Conversions
Old Mar 25, 2026 | 11:11 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Odd your acceleration feels slow, you should be right at or near the torque peak at 3000 rpm unless youve got a hawg a$s cam in there.
Old Mar 25, 2026 | 01:10 PM
tbear853's Avatar
tbear853
Originally Posted by motorsickle1130
.......Im running 3.54:1 on 32.5” tires with 1:1 final, and turn 2200 rpm at 60, 2550 at 70, and just shy of 3k at 80. Plenty of scoot with a rebuilt big block and 4spd.
Just playing around ...... My size 31x10.5R15 tires I guess have a 30", maybe even a hair smaller "rolling diameter" which is accounting for the flat base at contact to be nearer perfect. I am pretty sure the Dana 44 front axle is 3.54, but the 9" rear is 3.50 ratio which is the one used on a highway. TC high @ 1:1, and I plugged in 1.03 for the trans high to allow for 3% converter slip in high ....... then that conversions calculator link shows 60 mph to equal 2,422.5666666.... mph. OK, so I guess it's close enough, my tach and speedo needles are some bit wider.
Drake12
Feb 14, 2020 02:41 PM
Joe Meg
6.7L Power Stroke Diesel
Jan 18, 2010 05:35 PM
boogity24
Dec 18, 2003 10:29 PM
pee wee
Bronco II
Aug 3, 2001 06:19 PM
jowilker
Nov 8, 1999 09:06 AM
